Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Vendors Classifieds
      11-01-2012, 03:56 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
814
Drives: Independent Tuning Specialists
:: ECS Tuning :: The only gauge that doesn't clash with your interior|OE Styling
Need a complete boost gauge kit for a custom application? ECS proudly announces our new universal Boost Gauge Kits. Each kit contains a 42mm illuminated boost gauge, plus pressure transducer, wiring, and hoses.
Just tap into a manifold vacuum source at the engine using the enclosed vacuum tee. Then run a vacuum sampling line into the cabin and connect it to the transducer. Plug in the transducer, and connect the gauge to power with the wiring harness and bullet connectors in the kit.
This versatile package makes it easy to install this bright, accurate gauge, in any car.
Click HERE to order your ECS BMW 45mm Boost Gauge Today!!!!!!!!!
Not for use in Valvetronic Motors
      11-06-2012, 09:55 AM   #2
ECSTuning
ECSTuning's Avatar
814
      11-20-2012, 02:48 PM   #3
ECSTuning
ECSTuning's Avatar
814
There is no better time to buy than NOW!!!!!!!!!!!!!!!!!!!!!!!!
The best boost gauge for your BMW from ECS Tuning is now 15% OFF as part of our 8th Annual Holiday Extravaganza!!!!!!!!
      12-16-2012, 09:14 PM   #4
howiedds
D.D.S.
howiedds's Avatar
31
Drives: 12 AW E70 X5d
does this fit the e70 x5?
Current: Jeep GC Overland Hemi 4x4
TOTALED: 2012 AW X5d with Sport+Prem, (Heartbroken how she left me)
RETIRED: 2009 SG e92 M-Sport( I will miss you....)
      12-17-2012, 09:12 AM   #5
ECSTuning
ECSTuning's Avatar
814
Our vent pod is not designed for the E70. But the gauge can be used for custom applications in the E70.
