      10-26-2012, 11:15 PM   #1
mikikuki7
mikikuki7's Avatar
Drives: Searching for X6M or M8
Wind noise & rattle noise
I have quite a kind of loud wind noise coming as it appears from the front windshield or from doors... Specially from the passenger side...
Anyone?
Do you have wind noise from 40 and up? Also a rattle noise from me rear passenger door...
      10-27-2012, 03:00 PM   #2
doubleroll
Drives: 2022 X6
2022 BMW X6  [0.00]
2002 BMW 330Ci  [0.00]
2012 BMW X6  [0.00]
Not on my X6 but my 330 had to have the weather stripping around both doors replaced. BMW did it under warranty.
2022 X6 40i
      10-27-2012, 06:11 PM   #3
BimmerX62010
Drives: X6
Is it the original windshield? Check that it has the BMW logo on it.
While driving over 40 mph, have your passenger press the top/side of the windshield where the sound is emanating from and see if it stops.
Either way, could be a bad seal. To verify, you can bluetape the joints and see if the sound stops.
'10 X6 5.0i with 7RR Performance Package
'04 X5 4.4i with staggered 20" #168
      11-05-2012, 10:32 AM   #4
rios0311
Puerto Rico
14
Drives: 2010 BMW X6 ActiveHybrid
I had a bad rattle from my right side passenger rear door. BMW took the door pannel down and found a cable (inside the door) that had come off it's retaining clip. It was slapping against the inside of the door. After they secured the cable the rattle went away.
Prior to that, I could duplicate the rattle by banging on the lower outter edge of the door panel.
      11-05-2012, 02:03 PM   #5
Jess///M
Drives: 2016 X6M
My X6 has been pretty quiet with respect to windnoise. The M5 I had before this was really loud if I didn't have the sunroof shade panel closed (with sunroof also closed). Made it difficult durning phone cons for others to hear me while using bluetooth through the installed microphone.
      11-06-2012, 04:58 AM   #6
JL350
Australia
20
Drives: 2.0D X4
I have had a seal on the top of the windscreen come loose (not a BMW). At speed the wind would suck it out and it would rattle against the roof. I used masking tape to hold it down until the dealer fixed it. You could tape over the seal until you isolate the problem area if it is not easy to find. Someone may have dragged a seal out when closing a door etc.
