03-01-2012, 10:56 AM | #1 |
Rep 52
Tuning Options
Finally going to make the change to tune my beast. Have a 2011 X5M and have been following the forums. Can I get some comments or opinions about the different tuning options? Currently considering Active Autowerkes(lower cost but only comes with 1yr grace period for reflashing), ESS (handheld device very handy,but dyno numbers not that impressive, Dinan( more costly,but great reputation) or Renntech(amazing dyno, sub 12sec 1/4 mile but expensive). Any or all opinions are welcome. Thanks.
03-01-2012, 12:13 PM | #2 |
Rep 152
Go with Dinan. I ran against 2 different X5M's with the AA tune an I pulled on both of them. I believe dinan understates and AA overstates their numbers. Plus u get the warranty with dinan.
Only other tune I would consider is renntech. |
03-01-2012, 12:58 PM | #3 | |
Rep 167
11' BMW X5 M
01' BMW M Coupe |
03-01-2012, 05:04 PM | #6 | |
Rep 152
03-02-2012, 11:01 PM | #7 |
Rep 773
How is the renntech tune installed ? Is it a device or do you have to go to a dealer.
I may do the dinan one the next time they have a 20% off sale. Jeff |
03-02-2012, 11:15 PM | #8 |
Rep 691
i want to get mine tuned as well and am leaning towards the dinan because of the warranty. the power figures for the dinan are also pretty good for being under a warranty
03-02-2012, 11:19 PM | #9 | |
Rep 152
03-04-2012, 11:38 AM | #10 |
Rep 52
Seems like Dinan is a popular option. Warranty aside, my other concern is reflashing. I have been told that if you bring the car in for service and they perform a software update, the cpu is reflashed back to the original specs. With ESS for instance, you can then reflash it back. Can you do this with Dinan or Renntech or will you have to go through the whole process again which may cost you more money and inconvenience?
03-04-2012, 04:53 PM | #11 | |
Rep 152
03-14-2012, 08:49 AM | #13 |
Rep 2,036
If you go to the dealership with a Dinan tune and there is a ECU update the car will have to be updated. BMW made this mandatory in late 2010, early 2011. Customers can no longer "opt" out of ECU upgrades when taking there car in for service, if they do any scheduled service will not be completed. Not to knock Dinan (they are great at what they do) but they use a different method of tuning which requires you to go back to the dealer where your software was originally installed..
03-19-2012, 03:30 PM | #14 | ||
Rep 423
03-19-2012, 03:34 PM | #15 | |
Rep 2,036
Some Dinan tunes require you go back to a factory tune before because of the method they use to tune. Please ask a Dinan rep to make sure. With our tunes there is no need to get back to stock at any point before going to dealership for service. |
03-19-2012, 06:47 PM | #16 | |
Rep 423
03-19-2012, 07:06 PM | #17 | |
Rep 31
Can you please elaborate on the ESS tune being the worst? I was very attracted to it for the sole reason that I can personally remove it before taking my vehicle to service and then install it back when I get the vehicle back. This also takes care of warranty issues - i.e. you just remove the tune before requesting service. My priority when it comes to the tune is not even highest gains - its the convenience and more low end/mid-range power and better throttle response. |
03-19-2012, 07:16 PM | #18 | |
Rep 2,036
03-19-2012, 07:53 PM | #19 | ||
Rep 152
If u remove the tune and put on 50-100 miles the dealer will have No way to see u ever had a tune.. However if ur car isn't drivable even if u remove the tune the dealer will be able to see it. But.. None of this really matters because on serious warranty issues I.e. blown engine or turbos for example.. BMW NA will ask the dealer to upload ur cars data to them before they approve the job. BMW NA is able to look at ur cars history and can tell u have had a tune when ur data history shows abnormal fuel maps, air fuel ratios, rev limits etc etc and then they tell u a $20000 repair isn't covered. This happened to someone I know. Google it. It's not just BMW. They dont usually sweat the smaller stuff so they may not catch it but if BMW NA ever looks ur screwed. |
01-17-2014, 05:48 PM | #20 | |
Rep 250
is this true?^ |
