      08-14-2011, 07:36 PM   #1
gatorbimmer
Drives: 2002 3.0 X5
x5 blower works - no air through vents
I have a 2002 3.0 X5. When we first start the car, the hvac unit works great(air blows through the vents you want, any speed you want), then after we have run the interstate for over 1 hour, we notice the air starting to slow down out of the vents. Even when we press the max button, we hear the fan blowing as fast as it can, however it will not come out of any locations. The buttons show the change in directions, we can hear the fan running, but no outlet for the air. We have replaced 3 different resistors but nothing corrects this. We can then let it cool down for 30 min or more and it works fine for about 15 min and then starts to close the doors to the vents. Any Ideas?
      08-14-2011, 07:43 PM   #2
WWONG
Drives: 2012 BMW X5 xDrive35d
Sounds like too little or too much freon. That can cause it to ice over and it sounds like what you're experiencing.
      07-17-2013, 07:14 PM   #3
steveramputi2002x5
Drives: 2002 BMW x5
I have a 2002 x5 3.0 and have been experiencing the exact problem you mention. Did you resolve it and what was the fix?
      07-17-2013, 08:14 PM   #4
gatorbimmer
Drives: 2002 3.0 X5
air
It was the thermo coupler located under the dash( for the air conditioner). It was telling the computer that the air was not cold enough, so it continued cooling until it froze. After we turned the air off, it would thaw, work for a little, then freeze again. The part was cheap, the labor to remove the dash is where it hurts.
      07-17-2013, 08:50 PM   #5
steveramputi2002x5
Drives: 2002 BMW x5
Awesome! Thanks for the info. I'm headed to the dealer tomorrow for a quote!
      11-28-2013, 05:03 AM   #6
mkurniawansyah
Drives: 2007 E70
is this the evaporator temperature sensor?
