      05-25-2011, 05:47 AM   #1
Mondo123
Drives: X6 35d
22" Wheels on BMW x6 35D
Hi All, New to the forum and had a question about the X6 and wheel fitting.
I had previously the 20" Alloys with 315/35/20 rear and 275/40/20 Fronts. I bought a set of Onyx alloys which were 22" with the same offset all round. A spacer kit was fitted to the rear alloys to bring them out slightly so that they sit flush with the wheel arches. The Tyre sizes are now 285/35/22 all round.
315/35/20 = 28.68" Diameter
275/40/20 = 28.66" Diameter
285/35/22 = 29.85" Diameter all round.
From the above it suggested that the rolling Diameter of the original wheels are slightly different whereas the rolling diameter of the new 22" wheels should be exactly the same.
Does anyone know of a reason that the new wheels would make the handling on the car feel so much different to the old ones? The Tyres are a good make and are fitted to all sorts of performance 4x4 Range Rover Sport etc: so I dont think this would be the problem. The Car now feels very different and I am considering going back to the old 20" wheels instead.
Has anyone else had a similar issue with fitting of 22's to there X5 or X6?
Sorry for rambling on there..
Mondo
      05-26-2011, 02:39 PM   #2
Macca916
Macca916's Avatar
England
Drives: X6 XDrive35D
You've probably got non runflats on the 22"s which make a big difference to hwo it feels from my experience.
I swapped to OEM 21"s but with non RFTs and the ride is significantly softer than it was on 20" OEM RFTs and rims.
      05-27-2011, 03:43 PM   #3
TimZ
TimZ's Avatar
Albania
33
Drives: X5M
Going from rft to non-rft makes a difference on ride, I'm not so sure on handling but I would guess it feels softer?
Describe the difference that you feel, do you like it or not? Or are you concerned about the performance, etc
      06-04-2011, 11:17 PM   #4
Teflonx6
Drives: X6/X5/V8V
Can you post more pics of the wheels?
Tread pattern on your wheels will alter the driving dynamics as well.
