02-16-2011, 07:50 PM | #1 |
Supreme Allied Commander
3886
Rep 54,503
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Vorshlag Camber Plates For Your 1-Series
In order to properly use Vorshlag camber plates, you must choose the option below to include Vorshlag upper spring perches that match your strut brand and spring type. Vorshlag camber/caster plates are designed to be compatible with 2.5”, 2.25" and 60mm “coilover” style springs, OEM (stock) style springs and all strut types. We make numerous variations of this plate and accompanying perches to work with your set-up. The Vorshlag upper perches allow us to add a sealed radial bearing that isolates the spherical bearing in the camber plate from radial turning loads of of the strut shaft during steering inputs. This is part of why our plates last the lifetime of the car!
*Compatible with 2.5", 2.25" and 60 mm coilover springs, factory springs, OEM Style Lowering springs and all struts. *No need to change camber plates when switching from regular springs to coilovers - some companies sell you two totally different camber plates for coilover springs and factory style springs. *Installs with basic hand tools, no chassis modifications required. *Plates are designed specifically for BMW E82 & E87 (1 series) and E90 or E92 (3 series) chassis (except E90/E92 M3). *Caster & Camber are independently adjustable. *Camber is easily adjustable at the track from the engine compartment with simple (metric) hand tools. No need to reach inside the wheel well with a wrench to tighten. *The spherical bearing used in the Vorshlag camber plate is the largest used in any BMW camber plate on the market. The result is much better durability and wear characteristics than the undersized bearings used in our competitors' plates. *Designed for maximum suspension travel (bump travel). More than an inch more strut travel than some of our competitors' designs. *Alloy steel bearing holder - Tough as a German Tank! *Aluminum alloy main plate for lighter weight, engraved and fully anodized *All components plated or anodized for maximum corrosion resistance and long life. *Vorshlag Upper spring perches required. Coilover perches included in the basic price, but OEM style perches are extra (see "Spring Perch" drop down option menu, below). *Maximum negative camber setting depends on caster setting, ride height, and is ultimately limited by the strut tower opening on these chassis. The E82/90/92 strut tower hole is more restrictive than previous generation BMWs. *Expect to get -2° to -3.5° max camber, depending on ride height. *New and improved .25" thick top ring (introduced Dec 2008) for increased clearance between Vorshlag long reach M12x1.5 strut top nut to factory (faux) strut brace. Improved low profile bolt ring for more clearance when used with OEM style perches. Available now! Camber plates starts at $525 To order go to: https://hpautosport.com/product/vors...mber-plates-2/ May want to add some thrust sheets to your coilovers while you are in there: Last edited by HP Autosport; 08-09-2023 at 04:53 PM.. |
02-24-2011, 12:36 PM | #4 |
Rep 4,070
Hey guys on your page I didn't see KW V1's listed....what size upper spring perches would one order then?
02-24-2011, 12:58 PM | #6 |
Rep 4,070
^^^Good stuff man...I already have HPAutowerks bookmarked so I can pull the trigger in a couple months....
03-13-2011, 09:36 PM | #7 |
Rep 596
Bump for a quality product. Got these installed last week and the techs specifically mentioned their quality and the ease of install as compared to other brands they work with.
03-19-2011, 10:51 AM | #8 |
3886
Rep 54,503
Drives: F80 M3
All Vorshlag for E82/E9x are in stock. Including OEM, Koni, KW and Bilstein style struts, even the hard to find Ohlin coilovers.
04-25-2011, 03:23 PM | #9 |
Rep 150
for stock OEM m-sport suspension with E93 Front Sway, what do i choose?
Vorshlag - Camber Plates * OEM Style Springs E82/E9X Non-M Upper Perch (+$35.00) Vorshlag - Camber Plates Strut Type * OEM E82 E90 (+$25.00) Vorshlag - Camber Plates Bearing Type * Heavy Duty Double Row Bearing these correct for otherwise stock suspension? thanks! |
04-27-2011, 02:37 AM | #10 | |
3886
Rep 54,503
Drives: F80 M3
07-16-2011, 01:59 AM | #13 |
3886
Rep 54,503
Drives: F80 M3
Camber plates are back in stock for most OE, KW, Koni, AST and Ohlins applications.
08-22-2011, 11:06 AM | #14 |
Professional Rookie
35
Rep 533
Drives: 2016 M4
For KW V2's which one do I want, the 60MM upper perch?
2016 MGM/Sakhir M4 DCT | M-Adaptive | Not Stock for Long |
09-09-2011, 03:25 AM | #15 |
Rep 1,159
Got mine last week! Great Product and super faster shipping!
a side note, it does increase road noise a bit, doesn't bother me, just noticeable. |
09-23-2011, 05:45 PM | #16 |
3886
Rep 54,503
Drives: F80 M3
03-01-2012, 06:34 PM | #17 |
3886
Rep 54,503
Drives: F80 M3
Stock struts and spring...No problem!
KW's...No problem! Koni's...No problem! AST's...No problem! Ohlins...No problem! Moton...No problem! |
03-10-2012, 12:05 AM | #18 |
3886
Rep 54,503
Drives: F80 M3
Camber and caster plates
Get your Vorshlag camber plates at HP Auotwerks, Inc. Your largest West coast stocking dealer and installer for Vorshlag suspension parts.
We have been selling and installing these on E9x BMW's since 2006, no one on the West coast has a longer history with Vorshlag than we have. |
07-25-2012, 06:27 PM | #19 |
3886
Rep 54,503
Drives: F80 M3
We now stock JRZ 1M RS, JRZ 1M RS1, JRZ M3 RS, JRZ M3 RS1 and all none M 135i/335i RS and RS1 Vorshlag camber plates!
07-30-2015, 10:30 PM | #20 |
3886
Rep 54,503
Drives: F80 M3
These are slowly becoming available again. Wait time is down to about 2 weeks.
