| 05-05-2010, 10:51 PM | #1 |
![]() 57
Rep 99
No sport mode on x6??
Guys my bro got5.0 x6 but it has no ds mode WTF?? Is that because he doesn't have adaptive drive?? Help please aim ordering mine tomorrow and ds is a must have for me.
| 05-06-2010, 07:32 AM | #3 |
![]() 57
Rep 99
Ds means drive sport. I have it in my 335 coupe and 5 series. It's basically sport mode your car becomes very responsive and is used for aggressive driving. In the x6 when I switch the shifter to the left it shows me s1 and m1 m2 and so on. There is no ds or sport mode.
| 05-06-2010, 08:42 AM | #7 |
Rep 1,531
DS mode is when in D, shift the lever to the left (as you would if you wanted to go in manual mode) without changing gears. It will go into S mode (DS). If you push or pull it after it will go into M mode (manual).
No sport button if you don't have adaptive drive as others have said. T |
| 05-06-2010, 08:50 AM | #9 |
![]() 57
Rep 99
yea it does go into s1 mode is that just a new way that bmw makes sport mode ? because in my 335 coupe its known as DS mode for (drive sport). when he ordered the car he got sport activity package, he does not have adaptive drive
| 05-06-2010, 10:02 AM | #10 |
36th Chamber
16
Rep 131
Yep. It's the same thing DS & S1,2,3, etc. So you friend does have sport mode. If he did not order Adaptive Drive then there should not be a Sport button located behind the gear shifter. That button adjusts ride stiffness.
'11 BMW X6 xDrive 50i (E71) - Space Grey
'08 BMW X3 3.0si (E83) - Alpine White '04 BMW 745i (E65) - Black Sapphire Metallic '05 BMW 325i (E46) - Jet Black '99 Oldsmobile Alero - White |
| 05-06-2010, 10:14 AM | #12 |
![]() ![]() 13
Rep 373
I just got confused. I have the S mode button. When I push it, doesn't that put the car in sport mode or do I need to push the gear lever to the left as well? I have a 2010 50i.
| 05-06-2010, 10:17 AM | #13 |
![]() ![]() 32
Rep 321
As far as I know, the sport button below the gear shifter is just for the Adaptive Drive (suspension) settings. In order to get the transmission into "Sport" you need to push the gear shifter to the left as well.
| 05-06-2010, 10:23 AM | #14 |
![]() ![]() 13
Rep 373
ARE YOU SERIOUS? Dang it. That such bull$@#t. My salesman told me just to push the button. Only push to the left if I wanted to use it on manual. I haven't yet pushed to the left to drive it in manual mode. Once you push to the left with the sport button engaged, is there other options that are available, if so how are they performed? Thanks.
| 05-06-2010, 10:33 AM | #15 | |
![]() ![]() ![]() 265
Rep 437
as simple as this. u have the ''SPORT'' button meaning u have the Adaptive Drive option, which only changes the ride firmness on the suspension. putting the gear level to do left has nothing to do with the suspension but the transmission will shift more aggressively. |
| 05-06-2010, 10:39 AM | #16 | |
![]() ![]() 32
Rep 321
It's no big deal. Your salesman was slightly misinformed. Pushing the sport mode below the gear shifter = Sport setting for Adaptive Drive. Pushing the gear selector to the left = Drive Sport = Sport setting for the transmission Pushing the gear selector to the left and then pushing it forward or back and/or using the steering wheel paddles = Drive Sport - Manual Mode As far as I know, those are the only two "sport" modes available on the X6. My M3 has a sport button that changes the throttle mapping (more sensitive) ... it would be great if the X6 had that ... Last edited by Rac10000; 05-06-2010 at 11:03 AM.. |
| 05-06-2010, 11:03 AM | #17 | |
![]() ![]() 13
Rep 373
Here I was driving around with the sport mode button engage and thinking to myself, hmmm it does feel more aggressive then regular drive mode. I might've even told the wife, who was sitting next to me! Man, That's just wrong! Thx for clarifying cause I did not read the owners manual! |
| 05-06-2010, 11:44 AM | #18 | |
Starfleet Command
465
Rep 840
| 05-06-2010, 11:52 AM | #19 | |
![]() ![]() 13
Rep 373
| 05-06-2010, 01:48 PM | #20 |
Rep 18
On my 08 550 sport, the sport button definitely changes the throttle response.
2008 550 - Carbon Blk/Nat Br, Sport Pkg, Sport Auto Tran, Nav, L7, Cold Weather, HD Radio, rear seat heating, ipod
2003 Nissan Pathfinder LE AWD |
| 05-06-2010, 04:37 PM | #21 | |
![]() ![]() 13
Rep 373
| 05-06-2010, 05:11 PM | #22 | |
![]() ![]() 32
Rep 321
| Bookmarks |
