      04-09-2010, 02:56 AM   #1
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
Comfort access - how does it know who is driving if wife is in car?
Hi! I got a simple question. I understand that the comfort access option will open the car automatically when you are 1.5meters near the car. Then it will set your options in the car like seat position etc based on your memory settings in your key.
But what if your wife also has a comfort access key and she gets into the car next to you?
1. How does the car know what seat position to adjust to before u enter the car?
2. how does the car know who is driving? you or your wife.
      04-09-2010, 03:26 AM   #2
Dunzzy
Drives: 435Xd White
Ronald,
I had comfort access on my M3.
It sets the seat Radio Aircon etc based on the key in close proximity of the drivers door.
You need to touch the door handle to unlock the car.
It relies on you and you wife having separate keys.
I used the BMW supplied colour coded labels to identify different keys.
This was for the M3 not sure how it will work in the X6 although I would imagine that it will be very similar.
      04-09-2010, 03:33 AM   #3
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
Originally Posted by Dunzzy View Post
Ronald,
Dunzzy,
Thanks for the info. That means that even though you are sitting right next to your wife in the car, it can still tell which key is nearer to the drivers door even though the other key is just 2 feet away? That quite a precise system!
So if the key is in your pocket and you are driving. And you throw the key onto the backseat. what happens?
And even worse, you throw the key out of the window! How would the car react while you are driving at 100 on the highway?!
      04-09-2010, 11:17 AM   #4
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
Originally Posted by ronald_adi View Post
Dunzzy,
I believe it reads the key as you approach the drivers door, then sets everything according to what it read after that doesn't read anymore.
      04-09-2010, 06:13 PM   #5
727jbh
727jbh's Avatar
Drives: 2020 M8 GC Donington Grey
Memory is within the key fob, as long as you and your wife are using separte keys fobs.
      04-09-2010, 06:16 PM   #6
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
i am aware of that. but how does the car know who is sitting in the driver's seat when the 2 seats are only 1.5 feet apart!
      04-09-2010, 07:25 PM   #7
GJM
Xdrive
GJM's Avatar
Australia
Drives: X6 35d/X5 3d
Hi Ronald,
have never had both keys in the car at the same time, which ever key is used to open & start the car will determine the memorised settings. The car will remain running without the key in the vehicle, the warning sign appears when you exit the car with key in pocket, it just won't restart if you hit the stop start button.
gjm
      04-09-2010, 09:14 PM   #8
teagueAMX
teagueAMX's Avatar
Drives: Some are road worthy
It's a very weak signal.
      04-11-2010, 12:00 PM   #9
CoachmanX6
CoachmanX6
Drives: BMW X6 35D
Hi Ronald
With comfort access the seats, external mirrors etc, are set to who opens the drivers door ie by zapper or by touching the drivers door handle, If my wife opens the passenger door first by the door handle the drivers seat etc do not change from the last setting. I hope this helps as we both carry our keys on us most of the time we are out.
      04-11-2010, 02:43 PM   #10
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
CoachmanX6, thanks for the explanation. But i have a qs. When your wife opens the passenger door, how does the car know its your wife? Because of the closer proximity of her key to the passenger door?
      04-12-2010, 11:36 AM   #11
CoachmanX6
CoachmanX6
Drives: BMW X6 35D
Hi Ronald
I beleve that the antenna in the doors works on the proximity of the key, If you stand appx 1mtr from the door the door cannot be opened by another person, therefore my wifes key is not sensed by the drivers door antenna.
      04-12-2010, 11:53 AM   #12
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
ok. that sounds logical.
