04-17-2024, 02:58 AM | #1 |
Rep 2
E70 LCI folding mirror help pls
Morning all, new here and looking for some advice. I've always found answers over the last 20 years on forums using the search function etc. But I'm stumped this time. I have recently acquired an E70 LCI with memory seats and camera in wing mirrors. The mirrors tilt, but the passenger mirror won't fold when pressing the button inside the vehicle. The drivers side does. My question is, where the heck is the motor for it? I can't hear any motor sound when the button is pressed. I've taken it somewhat apart. Is it in the arm of the mirror? And can it even be replaced? Any advice would be greats, Cheers all
04-17-2024, 08:01 AM | #2 |
Rep 876
Sorry, wrong answer. I’ll keep looking….
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
04-17-2024, 11:35 PM | #3 |
Rep 385
Drives: '23 AMG GLE53, '10 X6M
Pretty sure it's in the arm.
See details at: https://www.realoem.com/bmw/images/diag_4fxb.png |
StradaRedlands5030.50 |
04-18-2024, 01:47 AM | #4 |
Rep 2
Cheers for the reply buddy. I had checked Realoem pictures but didn't really confirm it. But logic is telling me it has to be in the arm due to where it folds....just hoping I can try and replace the motor only...fingers crossed. Cheers again
05-08-2024, 04:53 PM | #5 |
Rep 16
It's probably hidden under the bottom plastic part. I have the exact problem but opposite of you, the right side fold but the driver doesn't. I've had the motor in my toolbox for at least three months now waiting for some time to do this. However I still haven't found a tutorial for it.
Good luck and let us know if you do find how to replace it. |
05-21-2024, 05:34 PM | #6 |
Rep 385
try this:
step 1-image 1 Fold outside mirror (1) forwards. Remove cap (2). step 2-image 2 Press together catches (1) of plug (2) and press plug (2) through in outward direction. Unlock plug (2) on contact carrier (3) and pull out. step 3-image 3 Carefully release catches (1). Feed out mirror electronics (2) with cable.
'10 X6M
'08 Cooper S |
05-21-2024, 05:36 PM | #7 |
Rep 385
there are Necessary preliminary tasks:
Remove drive for door mirror Remove housing on door mirror Remove mirror lemme get those instructions for you
'10 X6M
'08 Cooper S |
05-21-2024, 05:37 PM | #8 |
Rep 385
67 13 001 Replacing drive unit for electrically operated left or right exterior mirror -Release screws (1) and remove drive (2). image A -Installation: Fit drive for electrically operated exterior mirror (1) so that pin housing (2) engages exactly in plug housing (3) and locators (4) slide into guides (5). image B
'10 X6M
'08 Cooper S |
05-21-2024, 05:43 PM | #9 | |
Rep 385
Its #8. its right behind the mirror. its that round looking part. https://www.realoem.com/bmw/images/diag_4fxb.png
'10 X6M
'08 Cooper S |
