11-17-2023, 06:53 PM | #1 |
Rep 961
oil cooler line leak? x5m
Does the location of this leak seem like it would be oil cooler lines? Or maybe leaking front of the oil pan, though it seems too far forward.
I’ll check those things but wanted to see if there is anything else I should be looking out for. Turbo oil return lines were replaced earlier this year. Doesnt look like it’s leaking from the back of the block.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
11-29-2023, 09:47 PM | #3 |
Rep 961
The undertrays were pulled off to try and find the leak. I’ve got another car to drive in the mean time fortunately.
Lots of oil everywhere, not surprisingly since it’s been leaking a while. After spending 30 minutes under the car with it running the only active dripping I could see was from the oil cooler lines. Seems like the subframe needs to be removed, or lowered at least, in order to replace the lines. Probably makes sense to do the upper and lower oil pan gaskets at the same time. Doesn’t look like fun work on jack stands. Anyone here done this themselves, have any advice or tips to share?
ED 6/29/10 |
12-01-2023, 02:21 PM | #6 |
Rep 267
Drives: 2006 Z4 M Roadster
Before you start dropping the subframe (and engine with it), I’d recommend taking some Brake Kleen and clean / degrease the engine, oil lines and all other grimey parts. Then drive it some and see where the oil is coming from.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
argento539.50 |
04-04-2024, 06:30 PM | #9 |
Rep 961
I almost don’t believe it, but I think I’ve got a leak from one of the metal oil cooler lines. And not from where it’s crimped or at a connection. This is the area of the line that is normally covered by a support bracket. No oil coming from above the line or running down it from a higher spot. Must be a little pin hole.
ED 6/29/10 |
StradaRedlands5039.50 werdn670.50 |
04-05-2024, 08:44 AM | #10 | |
Rep 3,091
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
If that's it, how hard will it be to replace the line? |
04-05-2024, 05:32 PM | #11 |
Rep 961
Ista says the subframe needs to be dropped to replace this line. I think it’s doable just slightly lowering it though. Anyway I’ll end up dropping the subframe to also replace the upper oil pan gasket at the same time. I’m thinking it’ll take me at least 20 hours, working outside with the car on jackstands.
ED 6/29/10 |
StradaRedlands5039.50 |
04-05-2024, 06:17 PM | #12 | |
Rep 3,091
