06-12-2023, 02:25 AM | #1 |
Rep 532
Drives: 2007 E70 4.8i, 2008 E90 335i
E70 vs F15 Front struts
Does anyone happen to have an E70 and F15 strut to compare side by side?
I started to look at some picutres of them and because they share the same bottom suspension piece on the bottom side they have to match there but the F15 seems longer with a different spring hat. E70 EDC struts are very expensive as we know and the valve looks essentially the same on the F15.... The satellite control module is different but it seems like it could be mounted in the same place on the F15 strut with an adapter plate. So that leaves me with the question of just how different the lengths, springs, and top mounts really are... It is tempting to buy an F15 strut to compare but it would be better if someone has both laying around.., Thanks, Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
06-12-2023, 02:05 PM | #2 |
Rep 532
From what I can see the F15 struts have a much higher spring perch and much shorter springs. If anyone knows the overall length that would be useful.
I purchased a cheap F15 strut mount to see if that would fit on my e70 (or if it is similar enough to where the e70 version could be used in its place with the F15 spring setup). The rear shocks on the F15 also seem similar to the e70 but have less threads on the top so it is a similar situation to see if the top mounts can be exchanged or not. -Rich
06-14-2023, 04:49 PM | #4 | |
Rep 532
My question is "Are they adaptable." (adaptive drive pun intended) At a minimum a bracket will be needed to attach the e70 satellite module. It seems like some functionality in it might have been moved off from the strut on the F15 because it uses a clearly different module (unless it turns out that that module is compatible (which I doubt). -Rich
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. Last edited by rbryantaz; 06-14-2023 at 06:25 PM.. |
06-26-2023, 10:40 PM | #5 |
Rep 6
I'm interesting to see this post.
My attempt is to replace BMW X5 E70 front strut with EDC by F15 strut. I'm not worried about length but I'm concerned about compatible of EDC function, it means to use F15 strut satellite module (sensor) for E70. please advise is it possible/compatible? is there any coding for this? thank you very much for you advice. |
06-27-2023, 12:07 AM | #6 | |
Rep 532
I have a custom pwm controller on my e90 M3 edc shocks, in general the control valve is a PWM driven solenoid so unless the ranges are different it should work.... Can you check the resistance across each with an ohm meter? I expect it to be about 2.5 ohms. It may read 4 or so on a meter (to check touch the probes directly and subtract that reading from what you get on the shock). My idea is that a custom bracket would be needed for the e70 satellite module. It will probably need to be mounted pretty accurately. From this document the VDC does have "vertical position sensors" in the satellite modules: https://www.google.com/url?sa=t&sour...DVrxwmPT39YqmZ The top mounts and springs will all need to be f15 or e70 because the springs and mounts are different. So we need to figure out how close the overall length is. A small spacer may be needed on the f15 top strut mount because of the extra lip on it. Screw it, I just bought a pair of F15 struts and springs so I have them in hand to compare against.... Worst case I will re-sell them if they don't work. -Rich
06-27-2023, 03:00 AM | #7 |
Rep 6
Thanks rbryantaz for your clarification.
I'm a amateur on automation, I bought these struts and attend to ask mechanic to replace (let's say plug and play if possible). I'm waiting for your DYI then take lesson learnt/your comment to go my case. |
12-25-2023, 04:33 PM | #8 | |
Rep 3
01-23-2024, 01:49 AM | #9 |
Rep 532
They are very close.
If the F15 top hat is used it will need a 3-4mm spacer over the lip on the hat to work correctly against the e70 shock tower. My e70 is dynamic drive so it needs extra work to mount the shock satellites that I haven't gotten to yet. Once I finish some upgrrades on my e90 I will get to work on this project. -Rich
Tags |
edc |
