      12-02-2021, 07:30 AM   #1
Al3029
Drives: 2012 E93, Msport, white/red
E70 Lift Gate Module
Hey, my module burnt out due to it being soaked in water. Searching for a replacement with the same part # and not having any luck.
Can a module with a non matching part # be coded to work properly?
Thx!
      01-01-2022, 09:44 PM   #2
Musk
Drives: 2013 X5 50i
I've been battling tailgate lift issues as well.
I found this video, hope it helps!
https://youtu.be/JBhoU37Wi24?t=187
      01-06-2022, 12:25 PM   #3
SupDuc
Drives: Toyota
Hey I had a similar issue. I used a different part number lift gate module from a local guy who was parting out a pre-lci on my lci X5 and it worked fine without needing to code. Plugs were the same although the board and plug placement were slightly different and it even re-coded to open/close via the button afterward.
Also, my module got wet due to a leaf getting caught in my rear sunroof drain. Make sure that you clean those out with a wire and/or compressed air. Also take a small drill bit and drill a hole in the plastic plug in the wheel well for added protection against it filling up with water again. Electronics submerged in a tub with no drain is a recipe for disaster.
Al302923.00
      01-08-2022, 01:04 PM   #4
Al3029
I found one with a different part # and It would only open with fob and interior button. Wouldn't close, I had to close it manually…this one burnt out as well …Lol, smh..
Still searching for identical part #, since then i drilled a few holes so that the water will drain and wrapped the bracket with flex seal.
