      10-20-2019, 12:45 AM   #1
SpaceGrey_E70
SpaceGrey_E70's Avatar
Drives: 2011 BMW X5
2011 BMW X5  [0.00]
Thumbs up 2011 BMW X5 35i - Remote Starter (idatastart)
Hello all,
I've been running a ADS-BM1 remote car starter on my 2011 BMW X5 35i for over a year now. I have had zero problems and it works great. I wanted to make a thread of my install to help anyone or if anyone is on the fence about purchasing one.
First off, the install was super easy. Everything was plug and play. Total time taken (if I would have known everything from the start) would be around 2 hours. I paid around $750 for the remote starter and an included transmitter kit (one 2-way remote and one 1-way remote). You are also able to remote start it by triple clicking the lock button.
INSTALL:
This PDF shows the install process: oem-idsrs-bm1-ads-bm1-en.pdf
Connect all t-harness connectors:
Picture of all connections to vehicle:
Name:  1. 3 Connectors.jpeg
Pictures of antenna install for transmitter kit:
Name:  2. Plastic Trim Removal.jpeg
Name:  3. Plastic Trim Removal.jpeg
Name:  4. Remove dome light.jpeg
Name:  5. Routing Wiring.jpeg
Name:  6. Routing Wiring.jpeg
Name:  7. Removing Map Light.jpeg
Name:  8. Running Wiring.jpeg
Name:  9. Running Wiring.jpeg
Name:  10. Antenna Plugged into Module.jpeg
Programming keys:
One part that is not covered in the video above is the KLON, This is done on a PC computer with internet explorer (special cable needed: approx $50-80). You'll need a username and password, just make one (select that you are an installer). Here is a video that shows how to KLON (start video at 7:02):
One part I had difficulty finding information on was how to sync my remotes to my antenna. This is what my remotes and antenna look like:
Name:  11. Remotes.jpeg
Size:  96.6 KBName:  12. Antenna.jpeg
Steps to sync remotes with antenna:
  1. Make sure all module programming/KLONing is complete.
  2. Set ignition to on position.
  3. Press and release the antenna button, then press and hold the antenna button. The antenna's leds will turn solid blue.
  4. Press once on the lock button of each remote (can pair 4).
  5. The antenna's leds will flash blue once for each successful pairing.
  6. Release the antenna button. The antenna's leds will turn off.
  7. Set igition to off position.
  8. Check to see if remotes work.
Hopefully this helps someone,
Cheers!
2011 BMW X5 35i || M Performance Package || BMS CAI
Sequential LED Rear Bumper Reflectors
LED DRL's with Signal
Last edited by SpaceGrey_E70; 10-20-2019 at 12:58 AM.. Reason: Video wasn't displaying
      01-08-2024, 01:39 PM   #2
chocofrost
Drives: BMW X5 e70
How do you program the keys if its comfort access keys and wont insert/detect by slot? The Module stays in red never turn green when comfort access keys was inserted. I only have 2 CA keys, I dont have standard key.
      01-31-2024, 01:11 AM   #3
SpaceGrey_E70
Drives: 2011 BMW X5
2011 BMW X5  [0.00]
I saw you replied on the X5 forum as well. Both of my keys were comfort access keys as well. As far as I know you have to use the key slot to program the keys. Did you follow the steps on the installation guide and the videos exactly?
You could try contacting the company for support: www.idatalink.com
What page # and step # of the process did you get to? I’m referring to page 5 and 9 steps.
I’m guessing that you didn’t complete page 5 steps correctly and are now attempting page 9. Did you flash both the module and the expansion pack at the very beginning?
I'm not sure about anyone else but a lot of the information/videos in my original post don't show on the Bimmerpost app, they only show on my computer in a web browser.
Tags
bm1, flash logic, flashlogic, idatastart, remote car starter, remote starter
