10-07-2019, 03:38 PM | #1 |
Rep 5
When to replace X5 5.0i front discs?
Hi - the car is driven by the wife (Boss) and has 132k Km on the clock. The dealer has said to replace the discs. Is this normal ( my H2 has 138k KM and is still on the original discs)?
T.I.A. |
10-07-2019, 10:25 PM | #5 |
Rep 5
Doctor///M1805.00 |
10-07-2019, 10:27 PM | #6 |
Rep 5
10-08-2019, 12:11 PM | #7 | |
Rep 994
disc brake life is impossible to predict. driving habits, brake pad choice, etc all determine its life and longevity. You inspect it periodically, at least yearly, or follow the service intervals when the dash lights pop up and then you inspect it. Typically, I can have rotors, last 2X the life of a pad. So I'll swap pads and pad sensors, and not have to touch the rotors, till the next time the pads wear out. |
10-08-2019, 01:29 PM | #8 |
Rep 491
You turn the rotors if they are warped but still have adequate thickness, warped rotors produce juddering and noise.
If you drive with a heavy foot with frequent hard braking, the pads and rotors wear out faster even if you have less miles. Its all about driving habits. Ideally rotors last three times as pads. |
