      08-17-2008, 11:53 AM   #1
simon š
Drives: bmw x6
how does it change the yellow sidemarker? ?
HI guys!
Does maybe anyone knows how to disconect yelow sidemarkers in bmw x6 and replace it with the silver ones?
Do I need some special tool to dislocate it?
If anyone has procedure book please post it here....
best Simon Š
      08-17-2008, 12:18 PM   #2
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Originally Posted by simon š View Post
HI guys!
best Simon Š
well,i will hit it at the wall and go buy new one,european.
just kidding,man!!
      08-17-2008, 12:37 PM   #3
yyzx6
Drives: 2009 X6 xDrive35i
Just slide in a dental floss and pull that out. There are 2 plugs on each of them.
2008 X6 xDrive 3.5i Apline White with Cheateau Nevada Interior.
      08-17-2008, 12:51 PM   #4
simon š
Drives: bmw x6
I konw that they are two plugs ,but in which end ,and with dental floss?
ok maybe its better to visit a dentist
      08-17-2008, 01:30 PM   #5
xDrive50i
xDrive50i's Avatar
Drives: '09 750i individual
HI guys!
best Simon Š
Have a look at this thread:
http://www.xbimmers.com/forums/showthread.php?t=157757
Here are the part numbers again:
SIDE MARKER REFLECTOR LEFT: 63 14 7 187 087
SIDE MARKER REFLECTOR RIGHT: 63 14 7 187 088
See below for item number 2!
Name:  X6 Side Marker Reflector left.jpg
You can just make out the two parts that hold the reflectors in place. Hope this helps.
2009 750i individual | Citrin Black Metallic | Platinum Merino Extended Leather | BMW Individual Composition Package (includes Sport Package) | Dynamic Handling Package | Multimedia Package | Technology Package | Executive Package
http://www.7post.com/forums/showthread.php?t=234432
      08-17-2008, 01:39 PM   #6
simon š
Drives: bmw x6
I didnt quite understand .I already have 2 silver sidemarkers and they are actually very cheap 2x (about 16 Euro).But on the picture above i see that some screwdriver will be needed or im i wrong?
best simon
      08-17-2008, 03:55 PM   #7
xDrive50i
xDrive50i's Avatar
best simon
Sorry, that picture shows a couple of different parts. You only need the side markers!
You also do NOT need a screwdriver unless you are removing other parts.
This picture is from the parts catalog. I only posted it for reference.
Where did you get the side markers from if you don't mind me asking?
      08-17-2008, 04:25 PM   #8
yyzx6
I got mine on ebay for $50.
      02-05-2009, 08:50 PM   #9
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
I was wondering if anyone had done this yet. I picked up a pair of silver reflectors , here is what the back really looks like.
I'm not so sure it's going to be that easy to remove old ones just using dental floss.
update : yup was very easy with dental floss.
      02-05-2009, 11:10 PM   #10
yyzx6
Extremely easy! Take less than a minute on each side. You just have to pull out the side with the metal clip then the other side will slide out easily. They just pop the new one in.
      02-05-2009, 11:54 PM   #11
cheaptrick
cheap
cheaptrick's Avatar
Drives: 335CIC & 35i X6
Yep very easy I did mine that way. Silver looks way better than yellow. Cheap
      02-06-2009, 01:13 AM   #12
dmlgc
dmlgc's Avatar
yyzx6
Do you know whicj end the metal clip is on ? front or rear ?
Does dental floss really work ?
Thanks
      02-06-2009, 10:36 AM   #13
yyzx6
Originally Posted by dmlgc View Post
yyzx6
Thanks
If I remember correctly, the clips are toward the front. But to make sure, you can use the new one as reference. You can use the shape of the reflector and distinguish which is for which side. I used dental floss and loop them 3-4 times so it's strong enough for the "pull" job.
      02-06-2009, 01:11 PM   #14
apollner
Drives: 2009 X6
Can you post a picture with the silver reflector? Best if you can do a before/after so we can see same car under same lighting conditions.
Tx,
ANDREW
      02-06-2009, 09:32 PM   #15
dmlgc
dmlgc's Avatar
great should get it done this weekend, will do b4 after picts.
      02-07-2009, 02:05 PM   #16
dmlgc
dmlgc's Avatar
Everyone was correct , piece of cake to do.
For those that asked for b4 and after pics.
      02-07-2009, 10:54 PM   #17
apollner
Drives: 2009 X6
HI guys!
best Simon Š
Simon,
Is your car Mineral Silver? If so, can you post a pic after you change the side marker so I can see how it would look on mine?
Tx,
ANDREW
      03-08-2010, 12:38 PM   #18
DMCab
Drives: 09 BMW X6 35i
yyzx6
Thanks
I just installed my sidemarkers. Actually, the clips are on the rear. It took me longer than a minute as previously state (more around 20 minutes) but that is also b/c I thought the clip was in the front. Dental floss works but I also needed a toothpick to get the dental floss around the reflector.
      05-28-2010, 06:17 PM   #19
ewrrod
Drives: 2011 BMW X6 ///M
Aside from eBay, can anyone recommend a good place to purchase these reflectors (front, rear, right & left). I have a 2011 X6M and I'm a bit nervous about purchasing ones for the 2010 X6. The body kit it a bit different so I'm uncertain as to which ones to buy. Does anyone know if the X6 ones fit the X6M and/or the 2010 vs 2011?
      05-28-2010, 06:58 PM   #20
REInvestor
Drives: X6 5.0i
http://roveractive.biz/product_info....oducts_id=1084
      06-01-2010, 10:57 AM   #21
Rayvkt
Rayvkt's Avatar
Laos
Drives: 2009 BMW X6 xdrive35i
best simon
Where did you buy it from for 16 Euro? Please share, I'd like to order one set.
      11-22-2010, 07:27 AM   #22
KreativeX6
Germany
Drives: BMW X6 50i
I got mine from the BMW dealer here in Germany, they were 15 Euros each.
