04-15-2019, 06:46 PM | #1 |
2022 M4 Comp Xdrive
1023
Rep 1,538
One step colder spark plugs and ignition coils
Hey guys, I want to swap out my ignition coils as I'm not sure when the last time they were changed out 71k miles.
RealOEM shows two ignition coil part #s: 12138657273 & 12138616153 but I see reference to Bosch 00044X8 (BOS-0221504470) on forums. However I don't see the Bosch ones listed as interchangable with the real oem part # just want to make sure I'm not running sub par coils. Im also running 3psi over stock boost....maybe I should use one step colder plugs...what are folks using? |
04-15-2019, 08:19 PM | #2 | |
Rep 912
Nothing wrong with the old OEM Bosch....but BMW switched to Delphi or maybe Eldor (can't remember at this moment) supposedly improved/better....a little research will nail that down... Last edited by Bilbofraggins; 04-15-2019 at 08:24 PM.. |
04-15-2019, 08:54 PM | #3 |
Rep 1,564
I've had bad luck with Bosch and Delphi coils, appears to be alot of fakes out there. There are some threads about fake Delphi coils inducing noise and causing issues. I recommend going with Eldor coils, they are more expensive and worth every penny. As for plugs, go with the NGKs laser iridiums. They are a step or two colder (depending on which one you get) and are awesome. Very expensive on Amazon about 22 each! But you can find them on eBay much cheaper. I myself am running NGK 97506, as I am getting ready to install my jb4 and see how hard you can push a 143 thousand miles n63 with just octane booster...if you see a small thermonuclear cloud in the southwest region of the US, do not be alarmed...it's just me...😄
Ebtahi9843.50 |
04-15-2019, 10:03 PM | #4 |
Rep 177
Drives: 2012 BMW X5M
Running NGK 95770 and BavAuto (RIP) HP coils here. Ran just the plugs with BMS stg1 and added the coils when I went Velos stg2
BMS mentions: These NGK 5992 Laser Iridium replacement plugs are one step colder than Bosch and are well suited for higher than stock horsepower racing applications. The plug gap must be manually set using a gap tool to the suggested 0.022". The tighter gap and exposed electrode design typically results in fewer misfires at higher power levels than the Bosch plugs. The trade off is a 15-20k mile life span compared to the 20-30k life span of the Bosch plugs. Note NGK has changed their part number for these plugs to 95770. These plugs are compatible with all turbo BMW motors including the N20, N54, N55, S55, and s63tu. |
9vapors653.50 |
04-15-2019, 10:16 PM | #5 | |
Rep 764
Drives: 2019 BMW X6M
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
04-15-2019, 10:47 PM | #6 | ||||
Rep 1,252
04-15-2019, 11:32 PM | #9 | |
2022 M4 Comp Xdrive
1023
Rep 1,538
Says s63tu but what about S63? |
04-15-2019, 11:32 PM | #10 | |
2022 M4 Comp Xdrive
1023
Rep 1,538
04-15-2019, 11:33 PM | #11 | |
2022 M4 Comp Xdrive
1023
Rep 1,538
04-15-2019, 11:38 PM | #12 | |
2022 M4 Comp Xdrive
1023
Rep 1,538
Ya Delphi is what real oem says, along with Bosch |
04-15-2019, 11:49 PM | #13 |
Rep 764
I'm all for safety but I think you don't need it. 3 PSI boost over stock is not going to get the OEM plug too hot to where it's going to start detonating. The downside to a colder plug when you don't need it is it's not going to get hot enough to where it will be prone to fouling.
2019 BMW X6M
04-15-2019, 11:53 PM | #14 | ||
Rep 1,252
Bilbofraggins284.00 |
04-16-2019, 10:10 AM | #15 |
Rep 177
I had misfires prior to swapping plugs on BMS stg1. Granted I didn't know the age of the oem in the truck.
once changed all was good- I got overboost occasionally. Bavauto HP coils have been solid- no issues, but yet they are unavailable anymore. I was researching plasma coils too...is that just overkill? |
04-16-2019, 11:33 AM | #16 | |
Rep 764
2019 BMW X6M
04-16-2019, 04:22 PM | #18 |
2022 M4 Comp Xdrive
1023
Rep 1,538
04-16-2019, 09:44 PM | #19 |
2022 M4 Comp Xdrive
1023
Rep 1,538
04-16-2019, 11:02 PM | #21 |
Rep 1,252
