      04-01-2019, 03:15 PM   #1
cjrivera
Drives: 2008 e93 M3 & 2012 X5M
M3 19" wheels as winter tires?
I have a set of M3 wheels 19" - style 220M from my e93 M3 (19x8.5 fronts and 19x9.5 rears).
The tire sizes are 245/35/19 fronts and 265/35/19 rears.
Would I be able to use these as winter wheels for my 2012 X5M?
I googled and searched, but couldn't find an answer.
Thanks!
      04-01-2019, 04:00 PM   #2
X5 MAN
Drives: 2011X5 50iM-Sport;2016X3 35i M
No
Too skinny
21 or 22 inch rims with 10 and 11 inch width
      04-01-2019, 04:00 PM   #3
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
I believe they are both 5x120. However, the rear wheels of the X5M have a hub size of 74MM, the wheels you have are 72.56MM, you'll need to get them bored out. which is possible at most machine shops or wheel refinishers
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
      04-01-2019, 04:28 PM   #4
cjrivera
OK. Thanks for the info everyone.
      04-01-2019, 06:15 PM   #5
95wildtt
Need mo $$s
95wildtt's Avatar
Drives: 2020 X4M Competition
Not sure the M3 wheels are designed for the added weight of the X5 either, just something to check.
Thanks,
John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan
1995 Dodge Stealth TwinTurbo
Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport
      04-01-2019, 10:17 PM   #6
gitee
Originally Posted by X5 MAN View Post
No
Too skinny
I've always wondered this myself.
The rear hub size for E70 X5M is 72.56mm. The front hub size is 74.1mm.
Also, the stock 18" wheels available on base E70 X5s are 8.5" wide. The stock 19" X5 wheel is 9" wide. Check out bmwstylewheels.com for some specs.
https://www.bimmerpost.com/forums/sh...php?p=18871687
      04-02-2019, 12:58 AM   #7
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
I have stock Style 300 wheels on my M and they are 20". There isn't much room left to go smaller with the massive brakes so I think that would also be an issue when trying to run 19" wheels as well.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
