01-21-2019, 09:25 PM | #1 |
Rep 15
I bought an amazing X5 xdrive50i! Should I return it?
Hi, new to the forum. My name is Matt.
I purchased a BMW X5 xdrive50i on January 12th. I was looking everywhere I could for clean one, and I finally found it. It is in mint condition, both inside and out, every option including DVD player with 67k miles on it. This was purchased from a dealer, however I pulled the Carfax report and the vehicle was a one owner vehicle that was serviced at the same BMW dealership multiple times, then turned into this dealership that I purchased it at. It is a high end used luxury vehicle dealership with a service department that specializes in Germain cars. I took the car home Saturday and immediately started to smell oil. I drove it around a little and the oil smell was filling the car at a stop. I took it right to the dealership and left it with service. They said something failed on the turbo and they needed to replace the turbo. I am now on day 9 without the car and am getting worried about what I just got into. I had a 3 day return policy (They had it back on day 2) I also have a 3 month/3000 mile warranty on the motor and trans. They have been accommodating and gave me a newer Acura TL as a loaner. What would you recommend I do? I am really excited about the car, I feel like I got a great price on it, but is this something I need to worry about? Thanks in advance. Last edited by heymattw; 01-21-2019 at 09:32 PM.. |
01-21-2019, 10:32 PM | #3 |
Rep 3,658
These vehicles (the 50i) have a lot of well documented issues, were you aware of those prior to purchasing? Very fun cars to drive for sure, but they can be very problematic and very costly to fix/maintain.
Unless you get a PPI and confirm all looks well, and have a good 3rd party warranty, you might consider returning it unless you're willing to deal with the cost of repairs. Do you have any maintenance records? There's some very big ticket items that are due right around the mileage you're at. |
01-21-2019, 11:57 PM | #4 |
Rep 1,564
If you own a 50i (or M for that matter)You absolutely MUST either: Be DAMN good working on cars or have one hell of an extended warranty. These are complex machines (did you know your car has three water pumps?) and unfortunately have quite a few things that can go wrong with them. The SAD part is that nearly all of it's problems are due to the high temps of engine compartment. For example, I can guarantee you that your oil smell is either the turbo oil return lines getting plugged from burned/cooked oil (the oil return lines run right next to the exhaust manifold) or the oil line return housing seal failing, again due to the high temps. If you keep this car, either get damn handy with tools (I've replaced both the previous mentioned items, parts really aren't that expensive online, it's the man-hours it takes to replace them) or get an AMAZING bumper to bumper warranty. The oil return lines can be cleaned and the housing is like 70 bucks...the labor however is around 3 grand if you go to BMW!!
Oh and THROW AWAY that piece of SHIT engine cover. You will litteraly add 30 thousand miles to your engines life if not more. Evil, just Evil covering up a reverse flow engine, trapping all that heat and frying all the plastic and rubber hoses and tubes. I recommend ditching your rear engine compartment seal also, airflow across a hot engine is good a thing. Last edited by Sophisticated Redneck; 01-22-2019 at 12:07 AM.. |
heymattw0.00 |
01-22-2019, 12:06 AM | #5 |
Rep 15
Thanks.
I am pretty good at working on cars myself if it comes to following directions. I have a full blown race car (LS motor) I've done a lot of the work myself to. That being said, I know this is a completely different beast. Are there any questions I should ask As red flags when confirming things were done properly? |
01-22-2019, 12:18 AM | #6 | |
Rep 1,564
01-22-2019, 12:20 AM | #7 | ||
Rep 15
01-22-2019, 12:26 AM | #8 |
Rep 1,564
Lol!! Well that's one way to avoid having to replace then at 100k (the waste gates wear out around then and start rattling/giving underboost errors) I rebuilt mine.....you have to weld them in and use a hydraulic press....NOT FUN...getting the old bushing out is a BITCH (I have a 132k on my 50i now)
01-22-2019, 01:10 AM | #11 |
Rep 175
Hey Matt one thing is having a car that you will enjoy working on like your race car, the problem with the x5 is not the tear and wear maintenance the problem is the unexpected will fail and when it does is one stupid sh**t behind the other . With the 50i I wouldn't be surprised the oil smell is coming from the valve stem seal a 8k job from the dealer.
2018 was a bad year for my single owner x5 35i that I bought back in 2016 with 68k. The oil filter and oil cooler housing started leaking , the parking brake actuator went bad, oil pan started leaking , in the middle of the summer with high 90's temp my a/c was blasting cold, parked the car to pick up my daughter from school get back to find out the a/c went bad, same week on top of that decided to open the sunroof get to heat out and just my luck it broke. I used to love working on my e46 m3 when I had it , it was fun in 5 years of ownership 2 or 3 thing when bad and it is sad to say but bmw reliability went south. The car is really fun to drive but it is a headache, my wife new and previous toyota highlander with 245k miles was running with 0 issues and thinking of that makes me think if I should run away from bmw. If you can return it walk away from it and don't look back there is not such thing as a great deal. Good luck |
heymattw0.00 |
01-22-2019, 03:26 AM | #12 |
Rep 1,564
Forgot to mention, jump up on BMWs site and see what items are still covered by their warranty. Some things go to 100k, others to 125k. If the previous owner didn't do the CCP, then your in luck. I blew out th foootwell module (it controls power windows, interior lighting, mirrors, etc) when I drained the batter yand tried to jump it at 115k, Chapman BMW replaced it for free and to the latest model thanks to BMW extending the warranty to 125k. Oh heads up, recall on airbag and turbo charger water pump, get em done for free of ya keep it and they have not been done yet
heymattw0.00 |
01-22-2019, 08:01 PM | #16 |
///M
270
Rep 385
Return it.
In the future do PPI at trustworthy shop or Bmw shop, before you buy another car,that will save you lots of money.
not rich enough to buy cheap
01-24-2019, 09:01 AM | #17 | |
Fashion Photographer
66
Rep 323
01-24-2019, 10:58 AM | #18 |
Rep 15
Thanks for all the reply's. I am letting them fix the car and getting it to my approval. I really do love the car and I'm a huge vehicle enthusiast so I decided to get a 3 year/36k mile warranty from Autopom. At $3400 I will feel so much better.
I don't have a loan on the car, additionally my business paid for the car after a very successful year. I'm going to see where it takes me. |
01-24-2019, 12:20 PM | #19 | |
Rep 491
Good decision. I love my 50i too I drive it hard on the Interstate See my pics |
01-24-2019, 01:54 PM | #20 |
Rep 709
Yeah!! Keep it, it sounds like you really like it. I like mine, too!
This way when things go wrong we can fix them and inform others!
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
01-25-2019, 07:36 AM | #21 |
Rep 360
I'll just add that my X5 is same color and wheels as yours and I really enjoy it after it has had the problem areas fixed.
I bought mine at 62k and have replaced all valve stem seals, turbo oil and coolant lines, plugs and coils, rear main seal, and all 3 water pumps by 92k. Everything is working well now. |
