04-17-2018, 08:42 AM | #1 |
Rep 3,035
Drives: 2022 BMW X5
green residue and lights questions
Hi guys, couple of quick questions, maybe somebody can give me some advice
1st. I was replacing the engine bay partitions past weekend and when opened the top engine cover saw some amount of dry green residue near the top hoses. I'm not sure what is causing that and what should I do about it? Please let me know... p.s. couple of bad pictures for reference... 2nd. this question is mostly for those who have Adaptive LEDs, recently I noticed when lights are on (low beam) the driver's side rings light up much dimmer than passenger side, same rings light up evenly high when on DRLs, again if anybody has any suggestions on how to fix it, I would defiantly appreciate it I'm not able to take pictures of the uneven lighting, maybe my camera not that good... Thanks all
04-17-2018, 09:43 AM | #3 |
Rep 3,035
Drives: 2022 BMW X5
I appreciate the answer, does this mean that hoses or clamps getting bad and there is a leak? Just wondering how soon this needs to be addressed?
04-17-2018, 11:14 AM | #4 |
Rep 119
It's a leak. If you look under that residue you will see the green stuff is dripping down below turbos. You can try to fix them in 3 phases:
1) replace the clamps and install them tighter. You can use generic ones with screwdriver tightening style. It will hold a while. 2) There might be room to shorten the hoses about 10mm. At least this is possible in 50i model X5. Cut them and tighten the clamps again to the fresh (now non squeezed) end of the hose. But not too tight this time. 3. Replace the coolant lines. It will be difficult to find the matching rubber pipes only, so you might have to buy the complete lines. |
boneca2000.50 |
04-17-2018, 12:22 PM | #5 | |
Rep 3,035
Drives: 2022 BMW X5
I know this needs to be done but I assume this is not must be done ASAP thing, so I should have some time for additional research!
04-20-2018, 09:16 PM | #6 |
i'm just saying
5739
Rep 2,634
when those pipes really start to leak you ll feel like a toxic smell in the cabin that burns nose and eyes pretty much.. then you can understand its time to change.. i had the same issue and changed those piping 1-2 month ago..
boneca2000.50 |
04-21-2018, 04:43 PM | #7 | |
Rep 3,035
Drives: 2022 BMW X5
I will need to replace cabin air filters soon and will clean up the area so I can watch it once its cleaned.
05-25-2018, 02:35 AM | #8 | |
Rep 55
Drives: Bimmers!!
Here's the OEM part numbers you need: Return hose- 11537598343 Feed hose- 11537598341 Here's a youtube video on how to replace them |
05-30-2018, 01:02 PM | #9 |
Rep 291
I replaced a couple of the hoses and when removed you can see how the heat has deteriorated the rubber hose which allows coolant to seep through.
Regarding the LED headlights, did you recently do any coding or firmware update to the car? Maybe some of the parameters have changed. I just mounted these lights to the car and need to finish up the wiring so I can get things coded. At this point the rings light up evenly but the DRL don't work. |
05-30-2018, 01:40 PM | #10 | |
Rep 3,035
Drives: 2022 BMW X5
As far as LEDs goes, no I haven't changed anything coding wise since I did LED retrofit couple of years ago where I coded them myself. I doubt that something has changed by itself, this could be another question to the dealer where I need to go to check on my keyless issue anyway!
05-30-2018, 04:09 PM | #11 | |
Rep 291
The FRMs are known to have issues since BMW still provides warranty for them. That might be causing the light issue. Maybe the dealer will swap it out under warranty. |
05-30-2018, 08:51 PM | #12 | |
Rep 3,035
Drives: 2022 BMW X5
that was the only time I did that kind of coding, I had to install older version of Windows thru VMware on Macbook Pro, I bought a cable thru amazon and got all the needed software thru some forum links. It took a little bit of learning but I was able to complete coding successful. I haven't touch any coding (except Carly) since and I don't even have that laptop anymore. I might have cable and all the software I used laying somewhere.
05-30-2018, 10:25 PM | #13 |
Rep 1,002
Dude just come over and I'll sort you out with the leak situation. Just dealt with this. Dealer wanted $1500+-? I solved it in 10 min with $5 worth of parts.
05-31-2018, 09:11 AM | #14 | |
Rep 3,035
Drives: 2022 BMW X5
but I'm glad it's doesn't take much time
