      11-18-2017, 04:12 PM   #1
Der Kaiser
Österreicher
Der Kaiser's Avatar
Drives: X5
CEL -- Code P203A
CEL came on last night and I checked the code today and it showed P203A --- "Reductant Level Sensor Circuit"
After researching it came down to an issue with the DEF tank issue. Anybody had this issue before? I would like to get some more info before I go to the dealer.
      11-19-2017, 01:10 PM   #2
JoeyBimX5din
Drives: 2011 BMX X5 Xdrive50i
its like a fuel sending unit, but for your pig urine container. There is probably a ohm chart that should show you what ohm level you should have at what DEF tank level, if you wanted or had the ability to troubleshoot it yourself.
I took a look through Mitchel. The BMW procedure has the tech look at the DEF level sensor through the scan tool, if there is a reading then it may be OK, if there isn't, verify the connector pins and if they are OK, replace the level sensor. If you don't have a scan tool that can see that pid, you may have to rely on the dealer
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD
1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about
1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter
      11-22-2017, 09:25 AM   #3
Der Kaiser
Österreicher
Der Kaiser's Avatar
Drives: X5
thanks for the info. I'll check it this weekend.
      11-24-2017, 01:10 PM   #4
Der Kaiser
Österreicher
Der Kaiser's Avatar
Drives: X5
Update -- The light was on this morning but after topping off the DEF it is gone. It took almost 2 gal. to fill both tanks. Hope this solved the problem. I'll keep you posted.
      11-27-2017, 10:25 AM   #5
JoeyBimX5din
how big is the DEF tank?
      11-27-2017, 04:39 PM   #6
Der Kaiser
Österreicher
Der Kaiser's Avatar
Drives: X5
according to this link: https://www.press.bmwgroup.com/usa/p...tem=node__4310
Active tank = 1.6 Gallons
Passive Tank = 4.5 Gallons
      11-30-2017, 09:59 AM   #7
JoeyBimX5din
so you were bone dry.
      11-30-2017, 10:04 AM   #8
Der Kaiser
Österreicher
Der Kaiser's Avatar
Drives: X5
not really. 3/4 gal in the primary and the rest in the passive tank. But I think there is room for more in the passive but I ran out of DEF. I'll get more this weekend.
      12-03-2017, 05:36 AM   #9
JoeyBimX5din
sorry, sleep deprived look at the forum. Thought the size of the DEF tanks was in quarts, not gallons.
Has that code come back? It is more then likely a fail DEF level sensor
