      10-18-2017, 08:16 AM   #1
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
Steering wheel adjustment not working
Getting in to the car yesterday I noticed that my steering wheel didn't move to adjust itself as usually it does.
I went to manually adjust the height but for my surprise there is nothing, the wheel isn't moving any directions, I also don't hear any sounds.
Anybody have any suggestions?
TIA!
      10-18-2017, 09:32 AM   #2
smyles
Drives: '21 X5
Fuse?
boneca2038.00
      10-18-2017, 09:57 AM   #3
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
Originally Posted by smyles View Post
Fuse?
I will have to look, I checked diagram and it looks like Fuse 12 is responsible for
(10A) Steering column function control module.
Thank you I'll report back if fuse is the issue...
      10-18-2017, 10:46 AM   #4
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
Fuse?
just open the fuse box and there is no such fuse in my case, still looking for suggestions...
      10-18-2017, 12:26 PM   #5
coolmayank
Drives: X5m
TIA!
Did you check in the IDrive in the lock section if the Auto settings are enabled, that might be related to your issue.
boneca2038.00
      10-18-2017, 12:39 PM   #6
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
can you provide little more details?
I'm not sure which lock section you referring to?
TIA!
EDIT: I think I just realized that you talking about locking/unlocking doors etc., is this right?
I will go and check Auto settings right now...
      10-18-2017, 01:06 PM   #7
coolmayank
Drives: X5m
TIA!
yes, thats what I suggested to check
      10-18-2017, 01:14 PM   #8
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
I just checked and no I don't see Auto settings...
All options in the Doors Settings are checked for All the doors, there is an option for return seat in to last driving position, that option is checked as well.
I tried to uncheck it and check it back but it didn't make a difference.
      10-18-2017, 01:36 PM   #9
coolmayank
Drives: X5m
are you able to adjust the steering using the lever. Did you press the M button to set the seat position in the memory?
      10-18-2017, 02:17 PM   #10
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
the lever doesn't do anything, also there is no sound of motor when I'm trying to use it, I've tried moving seats using different memories and none of them seems to trigger the steering wheel.
      10-18-2017, 03:11 PM   #11
UnicornM
UnicornM's Avatar
Drives: M
Could be to do with your new Avin setup conflicting with something?
boneca2038.00
      10-18-2017, 04:04 PM   #12
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
I?m thinking maybe I pushed some cables too hard, I will take the system apart again I still need to connect front camera anyway!
      10-19-2017, 10:38 AM   #13
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
Thank you all for advises, especially to BaggedX5
As it turned out the issue was with some loose connection behind the multimedia unit. It's been fixed and steering wheel adjustment works now!
Thanks again
UnicornM391.00
      10-21-2017, 05:08 AM   #14
UnicornM
UnicornM's Avatar
Drives: M
Glad you fixed it! But how ironic. After this post I noticed my steering wheel isn't coming to the memory position when putting the key in slot. I can move it via the toggle adjuster and it rises when removing the key but a pain when first entering to drive away I have to adjust to the correct position
      10-21-2017, 10:50 AM   #15
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
it is strange! hope u will also figure it out!
I'm still fighting my new system (GPS issues and front camera connection)
oh well, its always something...
good luck to us to resolve it all
UnicornM391.00
      01-08-2019, 02:40 PM   #16
702bdr
Drives: 2003 BMW X5 3.0i
Driver's seat switch
I had the same problem on my 2003 BMW X5.
It turned out to the the driver's seat switch believe it or not.
Last edited by 702bdr; 01-08-2019 at 03:09 PM.. Reason: revised after seeing problem was solved
boneca2038.00
      01-08-2019, 02:46 PM   #17
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
One way to check for sure is to try and adjust your seat. If it doesn't work this is your problem. Good luck...
I appreciate your reply, this happened over a year ago and I figured out the issue since, in my case it was related to loose wire while installing new multimedia system, it fixed itself when I reconnected the cables!
      03-14-2019, 12:03 PM   #18
applecran
Drives: 2011 BMW X5 35d
do you remember which wire it was? I just installed my Avin unit and slowly the wheel went from working, to only moving when i got out and in of the car automatically but the switch to adjust it not working. And now it does nothing.
      03-14-2019, 12:29 PM   #19
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
unfortunately I don't remember which exact wire or harness it was, just do what I did, reconnect and hopefully it will fix itself like in my case!
      03-14-2019, 01:23 PM   #20
applecran
Thanks, I'll pull it all back apart and see what's going on. Although my heated steering also isn't working, might be related, everything else on the wheel and the seat works.
      03-14-2019, 06:13 PM   #21
applecran
No dice, everything is connected back there. Must be something else. Anything know which of the two green relays in the front fuse box is for the heated wheel? Is that also for the telescoping?
      10-17-2019, 08:43 PM   #22
northoftheborder
Drives: 2009 X5 4.8
I am having the same problem. Wiring diagram says slots 1, 134 for steering wheel adjustment. Both fuses are OK. I too was fiddling with the head unit but everything back there seems fine. I'm assuming nothing for the wheel goes through head unit cabling (why would it?). Everything else on the wheel is working (heat, volume, turn signals, etc). All seat adjustments work fine. It's only tilt and telescopic not working.
