12-03-2016, 01:58 PM | #1 |
FDNY Engine 55
686
Rep 2,115
LED headlight Retrofit problems
I retrofitted the halogen headlights to LED a few months ago and absolutely love the way they look...on my way to work the other day I got a bunch of error messages popping up regarding the adaptive headlights
Has anyone else on here who did this retrofit gotten similar problems? I'm thinking maybe its a bad FRM3 module?
FDNY ENGINE 55...Liberalism: Find a Cure...http://www.xbimmers.com/forums/showthread.php?t=1127923
12-04-2016, 01:52 PM | #2 |
Rep 3,044
Drives: 2022 BMW X5
hi bro, sounds like a FRM3 module, I had similar messages before codding, try to re code again and see what happens!
Hope this help! |
12-05-2016, 04:42 AM | #3 |
FDNY Engine 55
686
Rep 2,115
I have to drop the truck off to my buddy and let him take a look at it when I get a day off. I accidentally hit a huge pot hole a few months ago that threw a few error messages regarding the adaptive headlights but by the time I got home every thing was working fine(NYC streets suck!!!)...I'm wondering if that may have effected the FRM3 module
12-05-2016, 08:25 AM | #4 |
Rep 2,062
There are forums that can flash the FRM3 in case it crashed vs most people assuming it needs to be replaced in case it got stuck into a bootloop mode. Just Google FRM3 repair and you'll find places that'll do the work or directions on doing it yourself.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
12-06-2016, 04:55 AM | #6 | |
FDNY Engine 55
686
Rep 2,115
I need to buy another scan tool(obd2) mine wouldn't give me any info after plugging it in the other day
12-06-2016, 08:37 AM | #7 |
Rep 2,062
Yeah, I "fried" my FRM3 when my battery died during the time I was doing the injector swap and/or when my front window was being replaced at my home...everything from headlights, power windows, etc all failed to stop working. My insurance got the window replacement company to pickup the tab and blamed them for hooking all the window sensors back up wrong. I searched around and found www.mhhauto.com or www.b m w coding.com(no spaces) and a few other forums of people who explained it's nothing more than a bootlooping error similar to when a PC would crash. Hopefully you get it sorted, that's a great upgrade I wanna do someday
Cattivo685.50 |
12-06-2016, 09:01 AM | #8 |
Tanzanite Blue II X5M Pilot
1059
Rep 2,040
Drives: M3, M4, X3 M40i, X5M
Did you replace your FRM when you added the LED headlights? If not, the older version may not be able to code them in properly. It will show the option to retrofit LED headlights in Autologic, but you have to have the right FRM3 module. I had all sorts of warnings similar to yours before I replaced my FRM3 with a new one. Once I replaced it, I was able to code it immediately and they have worked perfectly ever since. If you buy one, MAKE SURE IT IS ONE WITH THE ORANGE DOT STICKER!
Good point also on the pothole thing, but I still think it is the FRM. I have read many threads on about them as I am having an issue with my wife's X5d on the right side headlight. Everything works except the adaptive (side to side steering input motion) feature. It throws an "adaptive headlight control" in the central display, but not a whole list of malfunctions like you what is showing on your display. |
12-09-2016, 11:47 AM | #9 | |
FDNY Engine 55
686
Rep 2,115
The LED upgrade is one of my favorite mods as of yet, although it was expensive the new headlights really give the E70 a fresher look
12-09-2016, 11:53 AM | #10 | |
FDNY Engine 55
686
Rep 2,115
12-21-2016, 12:02 PM | #11 | |
Rep 2,062
Hopefully it's just a loose connection like you'd mentioned. Start the car and don't move it for like 15 min to make sure it's not a timing out issue vs just bumps.
03-26-2019, 08:38 AM | #14 |
Rep 1,252
They're stock headlights that he retrofit, and since you're so smart, I'm sure you see this thread is from 3 years ago...
03-26-2019, 11:34 AM | #15 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
This ^
10-26-2019, 11:02 PM | #16 |
Rep 101
Do I care? Close the thread then, smart guy. But I might find another open old thread.. Maybe you should have them all closed?
