      04-19-2016, 10:32 AM   #1
-c-
-c-'s Avatar
Drives: bmw
2012 x5 transfer case replacement help.
Hey guys, after 105k miles my transfer case seems to be on the way out as at tight turns I'm getting some shuttering, it also seems to have been an issue on the 2012 model year that resulted in a redesign later.
Is their any DIY's out their that show how to do the swap? It doesn't seem like I need to lower the subframe or anything. Just wondering how bad of a job it is to do myself.
Thanks!
      04-20-2016, 08:26 AM   #2
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I have no DIY suggestions, but if it ends up being outside your comfort zone, check out Bimmer Werkshop in Chicago on Montrose. Former Perillo techs, all work done for 1/2 of dealership costs using OEM parts. They are true enthusiasts.
virosky82.00
      04-20-2016, 09:46 AM   #3
-c-
-c-'s Avatar
Drives: bmw
Awesome ! Thanks !
      06-23-2016, 03:27 PM   #4
bmw745
Drives: x5
My friend , no need to change transfer case, all you have to do is to change small gear inside the transfer case , it's plastic part and it will not cost you more than 20$
      06-23-2016, 03:41 PM   #5
mirob
mirob's Avatar
Drives: M3CX
Not sure how close the AWD setup is compared to the E53, but on my previous vehicle (2006 4.8iS) I had the motor slipping that actuated the AWD system. Warning lights (ABS, DTC, 4x4) every time I put it in gear.
I could have replaced the plastic gear for cheap...hell, even the motor itself...but I decided to just spin the worn side of that plastic gear and put it back on (seems only one side of the plastic gear is used) to try it out first...no issues for another 20K miles until I traded it...
      06-23-2016, 05:30 PM   #6
-c-
-c-'s Avatar
Drives: bmw
So is it hard to replace ? Dealer tells me it was the clutches slipping in the transfercase
What's the part number ? Or where can I buy it ?
      06-23-2016, 05:52 PM   #7
smass
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
My dealer told me the same thing last week. My issue was solved with a software/ilevel update. What are your symptoms? EDIT, Just noticed symptoms in the first post. If you feel it in tight turns, then it is the clutches. Have you changed your fluid yet? $40 for a quart is worth the risk.
If indeed you need a TC, reach out to these people for parts. I have not found a repair manual but the repair does not look that difficult. http://www.ebay.com/itm/ATC500-700-T...8AAOSwfZ1WZb2f
      06-23-2016, 06:00 PM   #8
-c-
-c-'s Avatar
Drives: bmw
Yea it feels fine in a straight line and only tight turns and turning In reverse the transfer case shutters, changed the fluid and it helped immensely for a while but I know the case itself went through 4 design changes in the course of a couple years so the newest design is the best.
May just change the whole thing, these rebuild kits when all said and done are almost the same price.
Thanks for the info. Mines a 2012 model year.
Seems hard to find a good transfer case for this model year.
      06-25-2016, 08:41 AM   #9
mirob
mirob's Avatar
Drives: M3CX
Wasn't hard at all, would just have to make a ton of room underneath the vehicle to get to it..
However, our symptoms sound nothing alike, your dealer might be spot on, on this one...sorry I couldn't be of more help...
      07-04-2016, 03:11 AM   #10
och
Drives: .
2012 X5 xDrive50i  [0.00]
2018 BMW M2  [0.00]
2017 X6M  [0.00]
2013 Suzuki Bouleva ...  [0.00]
They replaced mine under warranty with 21,500 miles back in April. Also a 2012 5.0 model.
According to the paper work these are the parts that were replaced.
22-32-6-780-026 B1SA Transmission bearing
27-10-7-643-752 SA Transfer box
I bet a lot of people here have failing transfer box and not even realizing it. Its easiest to tell when making a slow U-turn - the car with feel as if the tires as slipping.
      07-04-2016, 09:41 AM   #11
-c-
-c-'s Avatar
Drives: bmw
Yea I'm thinking of just unplugging it until I get a new one. Won't have 4 wheel drive but it's the summer time.
      07-04-2016, 09:46 AM   #12
och
Drives: .
2018 BMW M2  [0.00]
2017 X6M  [0.00]
Can you elaborate? I'd rather mine was RWD!
      07-04-2016, 12:02 PM   #13
-c-
-c-'s Avatar
Drives: bmw
Yea the dealer just went under the front and unplugged the transfer case and the vibrations stopped so that's how they determined it was the transfer case. With the transfer case unplugged it failed to operate so the vehicle was smooth in tight turns again.
Since late 2013 their has been a new design released for our transfer case that supersedes all past designs (2011 - 2012 model ATC450). and is supposed to solve all issues from past models. So far their has been over 4 redesigns and the 2013 x5 model got an entirely new design that won't work with ours supposedly.
      10-08-2019, 07:15 PM   #14
Jack07
Drives: 2012 BMW X5
Help
Hi, i have shuddering issue with my wife's 2012 X5, referencing your quote, where can i find/buy the plastic part please.
txs
      10-09-2019, 04:41 AM   #15
Sophisticated Redneck
Drives: 2012 BMW X5 50i
txs
This
https://www.amazon.com/gp/aw/d/B01MG...b_b_asin_title
And this:
https://www.amazon.com/gp/aw/d/B01N4...b_b_asin_title
      10-19-2019, 05:11 PM   #16
englishtom1596
Drives: 07 BMW X3/ 98 BMW M3
txs
the plastic cog has nothing to do with the shuddering issue. The cog strips and causes ABS, Brake and 4x4 light to come on (i believe that's the 3). As said above, if its shuddering in turns then its a mechanical failure of the clutch assembly. You can try replacing the fluid and resetting the T-case adaptations but most likely it'll need to be rebuilt or replaced
      10-19-2019, 10:38 PM   #17
That is not correct. When the plastic gear strips, the adjustment arm in the transfer case will stay locked in its current position which is usually with sufficient pressure on the friction discs to cause the shuddering during slow speed turns.
This can easily be confirmed with a BMW OB2 reader like Foxwell NT510. It will show the current angle of the adjustment arm in the transfer case and it will not change when turning from very slow speeds as it should. On Mine the stripped gear did not cause any of the ABS/Brake/4x4 lights to come on but did throw a BMW specific code for the transfer case.
      10-20-2019, 12:00 PM   #18
englishtom1596
interesting. I've never heard of the cog causing issues with the mechanical operation of the box, just the electronic sensing. I'll take your word for it
      10-21-2019, 10:19 AM   #19
smass
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Was your plastic gear issue with your 5.0? I thought the plastic gear issue was more common on the ATC700 transfer case that came with the 6 speed E70. I have not read about any plastic gear issues on the newer ATC450 that comes with the 8 speeds transmissions.
      10-22-2019, 03:16 PM   #20
heatmizr
Drives: E70 X5 50i M-Sport
I felt mine going out right before my CPO warranty was ending, so I played dumb at the dealer and said "it feels funny when turning sharp". They did the same "unplug and see if it goes away" test as above and confirmed my suspicion, then REPLACED my transfer case at no cost. Well, the $50 warranty deductible. Which I happily handed over.
That was at about 55k miles.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      10-22-2019, 03:23 PM   #21
HedMan
Drives: 2011 X5 35i
The ATC450 TCs (which is what is on the 2011-12 X5) have a different actuator than the previous models.
Previously, the actuator looked like this:
Name:  ATC400 actuator.JPG
The motor (2) uses a worm gear to turn a regular gear (inside 4). That regular gear gets stripped and can be easily replaced (since the whole actuator unit can be removed from the TC).
The ATC450 actuator looks like this (#3):
Name:  ATC450 actuator.JPG
The actuator (3) is really just the motor. It turns a worm gear that turns a regular gear that is inside the TC itself, so there is no easy, $20 fix (at least as far as I have found).
I can confirm that disconnecting the wires from the actuator will make the shuddering at slow speeds problem go away...but it also disables ABS, DSC, etc., so is not a long-term solution. And without removing and cracking open the TC, I don't know if the shuddering is from a problem with the actuator (which would be an easy replacement), or is from one of the gears (which would require replacing or rebuilding the TC, I think).
The most reasonably priced rebuilt transfer case I've found is https://www.ebay.com/itm/BMW-X5X3-TR...oAAOSwYIxX23r2 ($1,450, but $400 is a refundable core fee) but it looks like it doesn't come with the actuator, so you would need to reuse the old one (or replace it for another $650-ish).
The process for replacing the TC looks straight forward:
1. Remove everything in the way (transmission support, covers, heat shield, exhaust).
2. Remove the drive shafts (from the engine, to the front, to the rear)
3. Unhook the wires to the TC
4. Unbolt the TC and remove it
5. The same in the reverse order
Nothing too complex, but looks like it would be difficult if you don't have a lift and some air tools.
SYT_Shadow11517.00
      11-17-2020, 07:53 PM   #22
asdf4fdsa
Drives: x5 e70 lci 35i
I had this same issue, and same diagnosis with unplugging the TC and shuddering went away. I also tried pulling fuses. Mine is a 2011 35i with an ATC450. At first I tried changing fluid, which came out grey, but didn't help, so I did a full rebuild. At first removal of the TC, the failed mount fell out of its position. Pressing in a new TC mount would be an easier fix than a whole TC rebuild. Hope this helps everybody for yet another diagnosis.
