      03-21-2015, 09:04 PM   #1
M3Newbie88
M3Newbie88's Avatar
Drives: E92 M3
My X6 Glove compartment doesn't open.. any ideas?
Was installing a light bulb that burnt out..closed the glove compartment and now won't even open.. I heard something but just doesn't open. Any ideas?
Thanks in advance.
      03-21-2015, 09:54 PM   #2
mleun481
Drives: 2013 X5M
could be a blown fuse. The below is for X5, but assume it would be the same for X6.
http://www.xbimmers.com/forums/showthread.php?t=577601
      03-21-2015, 10:20 PM   #3
M3Newbie88
M3Newbie88's Avatar
Drives: E92 M3
Hmm seems like it.. where do I buy a fuse from? expensive? from the dealership?
      03-21-2015, 10:46 PM   #4
mleun481
Drives: 2013 X5M
they're cheap - couple of bucks at most. check autozone, pep boys, etc.
even more info on the glovebox:
http://www.bmwmotorsports.org/pdf/e7...20Glovebox.pdf
      03-21-2015, 10:48 PM   #5
M3Newbie88
M3Newbie88's Avatar
Drives: E92 M3
Is there a specific fuse or just any fuse for a BMW?
      03-21-2015, 11:04 PM   #6
mleun481
Drives: 2013 X5M
Did you read the post I sent? It even has a pic.
      03-22-2015, 07:44 PM   #7
M3Newbie88
M3Newbie88's Avatar
Drives: E92 M3
I did.. its red and shows a number 10 but I searched online for some oem fuses and they don't show the number 10 hence I wanted to make sure I know what I am asking for.
I'll go and ask for a 10 or 15 as I watched the video on the post.. thanks again for your help!
      03-22-2015, 07:57 PM   #8
mleun481
Drives: 2013 X5M
10 amp fuse
      04-02-2015, 12:15 AM   #9
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
Thanks in advance.
Most likely it's a blown fuse
      04-02-2015, 01:22 PM   #10
M3Newbie88
M3Newbie88's Avatar
Drives: E92 M3
Yes it was.. changed it out.. if anyone needs to know its a 10amp red fuse and its the mini version not the normal size
      04-03-2015, 08:21 AM   #11
scrummie2
Vagabond
scrummie2's Avatar
Drives: 2014 X6M
2009 BMW M3  [0.00]
2000 328Ci Dinan 3  [0.00]
The doors don't just open mechanically?!?! Seems like just another something to go wrong if they are electric.
Coming soon
      04-03-2015, 05:19 PM   #12
M3Newbie88
M3Newbie88's Avatar
Drives: E92 M3
Yes electrical.. so either you get a new fuse or you won't be able to open it.. smart design from the Germans
      11-15-2015, 01:48 PM   #13
peter2772000
Drives: 2012 X6 35i Sport
THANK YOU THANK YOU THANK YOU
I had installed an LED bulb in my gf's glove compartment. Bulb lit up, then died. Swapped back the OEM, still nothing. Dicked around with it for a while, then got fed up and figured I'd play with it later. Shut the glove box and the journey began. Couldn't unlock the damn thing for the life of me...
I'm taking her X6 down to Florida to our winter home. We did the official importation a few days ago and I am to drive it down from Montreal on Thursday. Needless to say, the prospect of telling my significant other that I dicked with the truck and it now needs to go to the dealership ASAP before I drive the truck down stateside.......let's just say that I peed a little in my tighty-whiteys at the prospect
Back to the reason I posted. Thank you soooo much to the members who posted about how the glove compartment mechanism operates. I located/replaced the 10 amp fuse and now the glove box opens & the light........lights. I owe you guys my life LOL
PS: I didn't know that the Marquis of Sade helped design BMW's. I can't believe the complicated workings that were designed just to open a damn glove box.
      12-02-2015, 02:14 PM   #14
dreamalaska
Drives: 2013 X6 3.5i
The glovebox is a classic German Escher design. Take something that should be stupidly simple and convert it into a complicated contraption. What kills me is that they'll "decontent" the trim lines to save nickels and yet keep something that cost $$ and adds no value. I think on the new models they've switched to a standard mechanical opening design?
      02-07-2017, 04:27 PM   #15
bmwfugu
Drives: x6
Couldn't find the burned fuse for glove box
Hello,
Thank you for the post.
I ran into the same problem. I replaced all the bulbs to the white LEDs on my 2013 X6 (3.5L) and until the last LED in the glove box, where my screw driver touched the contact and burned the bulb, but also the glove box won't open (just make the clicking noise when hit the open button).
I followed the forum and inspected all the fuses, but I didn't find any burned fuses.
I brought my car to the dealer they said it would require them to open the entire unit and inspect the motor. Since my car is no longer under warrantee, I thought I can this forum for last help. I hope someone can kindly point out which fuse (and location number, front or back box) from the diagram below.
Thank you in advance !!!
      02-09-2017, 03:25 AM   #16
peter2772000
Which fuse panel did you check?
The panel in question is under the dash, hidden by a cover (I think) on the far right passenger side. You have to remove a screw or bolt, then pivot the panel down to see the fuses.
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      02-15-2017, 11:29 AM   #17
Blackland
Drives: 2014 X6M
2014 BMW X6M  [0.00]
I did this once, very aggravating. Yes, the fuse is in the passenger footwell fuse panel, not in the rear fuse panel.
2014 X6M (daily)
2015 S63 AMG (beach car)
2017 Alpina B7 (Wife)
      02-16-2017, 09:09 PM   #18
Mr.X6
Mr.X6's Avatar
Drives: x6 5.0
If you checked the fuses, and they all are fine then its another thing. I forgot what its called. But to get to it you have to take out the radio and completely remove the glove box. I have the receipt in my car. Once I look at it I will tell you what its called and how much I paid for everything including the work.
I bought simple LED interior lights and when I installed the glove box Light I used a flat head to pop the bulb out... DO NOT DO THIS!!!!! SMH what a dumb move by me, I figured only a fuse would go. Instead of paying 100 bucks for some simple LED interior lights I end up paying over 500 after everything was fixed.... Just happened on 2/15.... I will update tomorrow.
      02-16-2017, 09:10 PM   #19
Mr.X6
Mr.X6's Avatar
Drives: x6 5.0
Did you get lucky and it was only a fuse? Not me...
      02-17-2017, 07:04 AM   #20
Blackland
Drives: 2014 X6M
2014 BMW X6M  [0.00]
It was the fuse. I was installing LED lights and I touched the inside and outside of the bulb holder at the same time with the bulb, fuse blew. If I ever do an LED install again I will disconnect the battery first.
2014 X6M (daily)
      02-17-2017, 04:38 PM   #21
Mr.X6
Mr.X6's Avatar
Drives: x6 5.0
So my receipt says replaced glove box motor assy... the part cost 158... labor was 170.00
total was 371.58 + LED lights = over 500.00 SMH DUMB ME!
      02-17-2017, 04:40 PM   #22
Mr.X6
Mr.X6's Avatar
Drives: x6 5.0
Here is a thread step by step to fix the glove box
http://www.bimmerfest.com/forums/sho...d.php?t=660733
