THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning My Dyno with EWG harness+E40
      05-10-2014, 07:33 PM   #1
schap12
Drives: 2014 M235i Mineral Grey
Finally made it to the Dyno today did a few pulls. I have BMS intake, ER downpipe, M-perf exhaust, JB4 FF wires and EWG harness.
Map 0- 359hp 399ft
Map 2- 401hp around 480ft
For map 7 i ran into an issue it was cut off at 5800rpm at 426hp 512ft. Failsafe boost was set to 19 and didn't really want to raise it and risk anything.
Pretty happy with the results
2014 M235i Mineral Grey, JB4, ER DP, BMS Intake EWG Beta test, 35% e85,injen intake stage 3 fuel pump by fuel it
      05-10-2014, 07:41 PM   #2
JustinCredibleM
Drives: '15 GT-R, '02 996TT
Very nice! A few questions:
1. How are you mixing the fuel to get the approximate E40?
2. Was the baseline on Map 1 or Map 0?
3. Does your car have the 8AT? If so, how does it feel under WOT?
      05-10-2014, 07:43 PM   #3
schap12
Originally Posted by JustinCredibleM View Post
Very nice! How are you mixing the fuel to get the approximate E40?
And does your car have the 8AT?
I use the E85 calculator i http://www.intercepteft.com/calc.html
or http://e85prices.com/milesperdollar.htm
but generally its around 4-4.5 e85 and 8-8.5 of 91
      05-10-2014, 07:43 PM   #4
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
You said Baseline. Is that with everything installed and running the default JB4 Map 1 with E40 gas?
      05-10-2014, 07:44 PM   #5
schap12
Yes its 8AT
      05-10-2014, 07:45 PM   #6
schap12
Well baseline map 0 JB4 with everything yes
      05-10-2014, 07:46 PM   #7
schap12
Probably shouldnt have run Map 0 with e40 but w/e its done
      05-10-2014, 08:00 PM   #8
kerm1t
Drives: 17 M3 ZCP Stage 2
O___________________________________O
baseline seems really high for only e40.
whats JB4 FF wires? and did they release the ewg harness?
      05-10-2014, 08:42 PM   #9
schap12
e40 dp intake
      05-10-2014, 08:46 PM   #10
kerm1t
how about the JB4 FF wires and ewg harness??
      05-10-2014, 09:42 PM   #11
schap12
yes, everything was on it it was on map 0 though i apologize for the confusion i edited the post
      05-10-2014, 10:01 PM   #12
ShlemonboostedM
ShlemonboostedM's Avatar
92
Drives: 335i F30
360whp on stock boost levels ? Either it's crank hp or something is wrong here .. Make most sense that's it's 360cranck hp ..
      05-10-2014, 10:23 PM   #13
JustinCredibleM
I just ordered my FF wires lol.
      05-11-2014, 04:37 AM   #14
kerm1t
oh no, i was asking if burger made them available since they weren't before haha
i was wonder what the FF harness was since I've never heard of them
      05-11-2014, 06:50 AM   #15
JBizzle135i
Drives: M235i
The EWG harness isn't available to buy yet, some people have them to help with testing.
The flex fuel (FF) harness allows the use of E85 I think.
M235i Auto: Alpine White / Black Dakota Leather, Brushed Aluminium / High-gloss Black Interior, Driver Comfort / Professional Media / Sun Protection Packages, Harman Kardon Hi-Fi, Enhanced Bluetooth, Lumbar & Heated Seats, Adaptive M Sport Suspension
      05-11-2014, 10:26 AM   #16
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
This makes me excited, my downpipe, intake and JB4 should be here any day now.
On another note, has anyone been having rough idle issues with the BMS Intake like some F30 guys have?
      05-11-2014, 12:00 PM   #17
cmkde
Drives: Alpine White 15' M4
I haven't and I don't have the JB4 installed yet. I do know that BMS was talking of possibly slightly changing the design for people not planning on using the JB4 due to the exact reason you stated.
But you shouldn't have issues either way.
      05-11-2014, 02:09 PM   #18
Uponone76
Uponone76's Avatar
Drives: BMW M4
Why do you have to run such high octane gas to achieve 360+whp? What are the limiting factors of the N55 engine? I would think this motor should be able to get 400whp with the appropriate mods on just 93 octane.......
Where am I going wrong?
      05-11-2014, 10:41 PM   #19
JustinCredibleM
You "think" or know? I have yet to see the N54 or N55 motors make over 400whp on regular 93, but I have seen it hit 350-360whp though.
      05-12-2014, 05:53 AM   #20
Uponone76
Uponone76's Avatar
Drives: BMW M4
Obviously I used the phrase "I would think," hence me asking the question, why is this engine so limited?
Someone brought up the 2jz engine in another thread and it's a great example of what I'm talking about. It's a 21 year old inline 6 engine with twin turbos. No fancy Vanos, direct injection, twin scroll, or electronic waste gate. Yet with just exhaust and a boost controller (not even a tune), these cars produce over 400whp. With full exhaust, intake, boost controller, intercooler, and a tune (which is what OP is running minus the intercooler) the 2jz would produce over 450whp. And of coarse all of these numbers are repeatedly achieved using normal pump gas 93 octane.
So again, my question is, what is the limiting factor of these engines?
      05-12-2014, 07:56 AM   #21
F30form
Drives: '13 Mini Cooper S Hardtop
The turbos. The 2JZ has a much larger compressor and can breathe higher up. The "boost Threshold" is also much much higher on a 2JZ. Boost isn't built until 2700-3000, but then the usable range is much higher. The N55 produces peak torque from about 1500 rpm on, but power tends to drop off because of the small compressor.
      05-12-2014, 01:26 PM   #22
JustinCredibleM
This is a luxury vehicle and as such, there should be no such thing as "turbo lag" to the consumer. The Supra comes with larger turbos, hence why it can produce more power and has noticeable turbo lag. BMW created a very good engine, but left a tiny turbo so the response is more towards the low-end and so the consumer doesn't have to deal with their heads getting snapped back at 3500 RPM. Furthermore, since the N55 motors generate most of their torque under 2000 RPM, it shows there is virtually no turbo lag and the consumer probably wouldn't be able to feel it. The pros and cons of a small turbo is great low-end and turbo response, but leaves the top-end to be desired since the turbo runs out of air in the higher RPMs. If we had the same engine design and turbo size, then I wouldn't see an issue producing 400whp+ on regular gas. Take a look at some of the aftermarket turbo setups and you'll see these motors making close to 700whp without any internal modifications.
Its all based on reasoning and the design of the car manufacturer.
2addicts
