BMW 3-Series (E90 E92) Forum
can't find key icon on dash???
03-06-2014, 11:15 PM | #1 |
Rep 77
Drives: 2015 535i xdrive, 2014 x5 35i
i've had my car for 1.5 weeks. when i got it, i remember seeing the key icon, where i scroll through the items on the turn signal stalk.
however, now when i scroll through, the key is not on the list. there is all the other items, such as setting the dash light strength, check control, setting date and time, but no key icon. i tried opening, locking and opening the car multiple times. but still no key icon. any ideas? |
03-06-2014, 11:40 PM | #2 |
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Going through the 2007 manual and im not seeing it, what can you change with it?
This is all i see:
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
03-06-2014, 11:42 PM | #3 | |
Let's roll...
Rep 166
03-07-2014, 12:02 AM | #4 |
Rep 77
i'm trying to program some settings i believe get saved to the key. for example, when you click the open door button on your fob, you can set it to open just the driver's door, or all 4 doors. to program it, the manual says to scroll through the embedded scroller on the turn signal until you see the key icon.
when i scroll, i only see 3, 4, 6 and 7 on e92 enthusiast's image in his post. i want to see a key icon like is shown in my image below |
03-07-2014, 01:07 AM | #5 |
Let's roll...
Rep 166
Ah, I see. I have an owners manual pdf but it only seems to show how to access the key programing from the iDrive menu. It seems to be missing the part about programing it from the stalk. I am not near my car right now or I would check to see if it shows up on mine when scrolling through the menu.
03-07-2014, 02:24 AM | #6 |
Rep 2,203
Do this with ignition on or with the engine running. Settings are only available then.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
03-07-2014, 05:28 AM | #8 |
Rep 1,735
Yeah you push the button then scroll up or down on the menu. You then access your profile.
BTW you have to be parked, or the car not moving. If your in motion it wont show that setting. |
03-07-2014, 05:31 AM | #9 |
Rep 51
You set door locks through I Drive. If you saw a key on your dash it was probably because you we're out of the car while it was running and it was warning you that the key was not communicating with the car. A warning so that you do not drive off without the key if you have CA.
03-07-2014, 06:17 AM | #10 | |
Apprentice
86
Rep 491
03-07-2014, 07:59 AM | #11 | |
Rep 145
Turn car ON and stay in park the key icon with check mark will be there... BTW.... This is for NON-iDrive E90's |
03-07-2014, 09:13 AM | #12 |
Rep 77
just to add, i do not have i-drive. i toggle through these icons on my dash in between my gauges. i had tried with the key in the ignition, and with the car on, but in park, and in all cases couldn't find the key icon. i'll try again this morning and report. thanks for your help so far
03-07-2014, 06:27 PM | #13 |
Rep 77
when i went back to car it worked. i think i may have confused it last night by clicking the open/lock button too fast and too many times. all is good now. thanks for replies.
my key settings are now turn signal: 3x open all doors upon 1 click of open button daytime running off lock doors after putting in drive only flash lights (no audio) when unlocking/locking car if anyone has any different ones and they don't like one of the settings i entered, let me know |
