BMW 3-Series (E90 E92) Forum
parking brake loose already??
11-01-2007, 03:21 PM | #1 |
Rep 890
2k miles on the car and the parking brake seems a little loose already. My E46 parking brake was the same way, became loose very quickly. but my Audi A4 parking brake never losened up in 3 years. Anyone else noticed this on their BMWs?
2013 F30 328i
Mineral Grey/Everest Grey leather/sport line/8 auto/premium package/lighting package/navi/heated seats |
11-01-2007, 04:03 PM | #3 |
Rep 3,983
11-01-2007, 04:06 PM | #4 |
Rep 890
your cars a stick, and youve never used the parking brake??? how can that be?
2013 F30 328i
11-01-2007, 04:13 PM | #6 | |
Rep 3,618
To the OP: Yes I find that mine is loose about 99% of the time, seems that I have to pull up on the handbrake much further than I would imagine having to. I installed the split armrest and most of the time the handbrake just about touches the bottom of the extended armrest section, which certainly doesn't seem right.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
11-01-2007, 04:18 PM | #7 |
Klaatu Barada Nikto
30
Rep 1,169
I didn't intend to start a debate on the topic, but trust me, if the car is securely in first gear with the clutch released and engine off on level ground - it ain't rolling nowhere. Try pushing one some time when it in that condition. Good luck.
11-01-2007, 04:22 PM | #8 |
Rep 890
yeah, were getting off my topic here lol
2013 F30 328i
11-01-2007, 04:30 PM | #9 |
Rep 4,726
Mine too, either bring it in and have them tighten it or do it yourself. their should be a small plastic cover in the center console you can pop off too tighten the bolt.
11-01-2007, 04:55 PM | #11 |
Rep 513
6K on a manual and I'm finding that I have to pull harder/higher for it to hold the car too.
11-01-2007, 05:26 PM | #12 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Its not necessarily the fact that it will roll, its what happens if the car gets hit. Youre relying on the gears to stop the car from moving, but if it gets pushed or hit, those wheels are moving and youre chewing up some teeth in that transmission. If you pull up the parking brake, at least it will keep the car from moving when hit and if anything, the tires from rotating.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
11-01-2007, 05:30 PM | #13 |
Rep 1,243
Seems like the same issue as the E46 nothing you can do besides go to the dealer and have it tightened. I think my E46 lasted between 5k-8k miles before I had to have it tightened.
11-01-2007, 06:04 PM | #14 |
18125
Rep 9,385
We have a parking brake?
If someone hits my car, the parking brake ain't going to make much difference, and the "damage" to the gears from it being in gear will be no more than the damage I create when I drive with the engine on and downshift, probably. |
11-01-2007, 06:13 PM | #15 |
Rep 1,356
TAKE IT IN... no point in asking what you should do when the car is still under warranty..!
11-01-2007, 06:14 PM | #16 |
Vice Admiral
14
Rep 57
I think you might have something wrong with your car. My e90 automatically adjusts on the second pull, its part of the brake features. Someone back me up..
11-02-2007, 08:14 AM | #18 |
Bad Lieutenant
233
Rep 3,517
My 335 does the same thing, once a month, I ride it while I'm parking and that seems to help it "grab" as well; I think I read something in the owner's manual about using the parking brake to grind off possible corrosion on the drum in drum mechanism.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
11-02-2007, 09:33 AM | #19 |
Rep 703
Drives: '11 550i
11-02-2007, 10:44 AM | #20 |
Rep 890
with my E46, I brought it to the dealer and they tightened it with no problem. About 2k miles later, it was loose again
2013 F30 328i
11-02-2007, 11:36 AM | #21 |
Rep 1,928
i use the P brake every day i have 8000 miles and no not one isssue...funny my buddy has an m3 and it was loose on that also guess it was an e46 m3 thing
11-02-2007, 11:47 AM | #22 |
Bad Lieutenant
233
Rep 3,517
The parking brake is controlled by a drum in drum design; most rear disc brake vehicles are designed the same.
