Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Europe (Continental) > FS: E9x OEM Headunit with bluetooth, USB, and DAB
      01-02-2014, 04:43 PM   #1
makkan00
makkan00's Avatar
Drives: F83 and F36
HU from LCI car with BT, USB and DAB connections.
Its all OEM solution and better than after market kits.
Since the HU reads the audio files directly from the source, therefore sound quality is way better than standard HU.
How to fit? Part numbers required
Follow this thread.
You can always sell your HU to compensate your funds toward this.
Benefits of buying this headunit;
1- LCI chimes
2- Listen to your music through USB (HU uses its DAC, so better sound quality).
3- Listen to your music though ipod / iphone / bmw y cable
4- TCU/MULF units are no longer needed and if you have one, you can sell it.
5- It has built in DAB tuner so no external DAB units, no expensive retrofit kits.
These HUs are rare to find.
Looking for 540 Euros delivered.
Parts are listed in the link above. You will need to change your diversity antenna to one with built in DAB antenna or you may opt for aftermarket dab antenna.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      01-28-2014, 12:52 PM   #2
Tymm
Tymm's Avatar
Sweden
Drives: E92 325i 2007 sgm
I have prof nav on a 2007 e92 (no usb) would this be compatible?
      01-28-2014, 01:06 PM   #3
makkan00
makkan00's Avatar
Drives: F83 and F36
IF you have professional navigation (CCC), then its not compliant.
      01-28-2014, 01:31 PM   #4
Tymm
Tymm's Avatar
Sweden
ok thanks!
