BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > brake CALIPERS paint DIY
      10-18-2007, 09:03 PM   #1
xballashakalax
Drives: 2013 F10 M5
anyone now how to paint there brake calipers with the correct steps..?...i asked my mechanic and she said it isnt that simple because the brakes might "bleed" and have air holes in them if they are removed.....any ideas
2008 Interlogos blue e90 ( sold)
2011 MB c63 Amg ( sold)
2013 Cad cts-v (sold)
2014 Bmw F10 M5 (sold)
2016 BMW i8
      10-18-2007, 09:22 PM   #2
OhhaiAlex
Oh hai :)
Drives: M3
Leave the calipers on.
1. Get caliper spray paint and brake cleaner from automotive store
2. Masking tape and old newspaper for masking, old rags for cleanup
3. Jack one wheel up at a time or you could do all at the same time
4. Lay old paper on the ground under the rotor and caliper
5. Spray on the brake cleaner and get all the loose dirt off maybe use a brush if your is real dirty
6. Mask off areas around caliper and back of it to lessen over spray
7. Spray on light coats (4-6 coats) about 10mins a part
8. Remove tape and newspaper
9. Clean off any over spray with rag and brake cleaner
10. Put wheel back on a tourqe to specs.
11. Lower jack and enjoy the nice clean caliper now.
      10-19-2007, 01:23 AM   #3
xballashakalax
Drives: 2013 F10 M5
thanks white angel. just wasn't sure on the part of actually removing the calipers or not...have u actually done this
2016 BMW i8
      10-19-2007, 10:35 AM   #4
mds82
mds82's Avatar
364
Drives: 2006 325xi
Its 100 times easier if you buy the liquid paint Vs the spray on paint.
THis way you dont have to tape anything off, you just clean the caliper, then brush on the paint. you can get away with one coat as well.
      10-19-2007, 01:09 PM   #5
xballashakalax
Drives: 2013 F10 M5
what type of liquid paint?
2016 BMW i8
      10-19-2007, 01:13 PM   #6
mds82
mds82's Avatar
364
Drives: 2006 325xi
dupi-color
      10-19-2007, 04:45 PM   #7
BoostedBMW
Moderator
BoostedBMW's Avatar
Drives: TiAg E92 335
2003 S2000  [0.00]
I prefer G2 caliper paint for a few dollars more, but I agree that the paint-on kit is much better then the spray can. I have done them both ways.
-Michael.
Berlina Black S2000 CR is now in the garage
l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l
      10-24-2007, 08:25 AM   #8
HyperM3
Too many Alex's, from now on, call me Beaufort
Drives: See Sig
I picked up the paint kit from tirerack. Same kit I used 10 yrs ago on my other car. Paint is still on those calipers so I figured its gotta be good stuff.
Hand painting is much easier and detailed than the spray. No need to mask things off or worry about getting overspray.
Easiest way to do it is jack up the car completely and take off all the wheels at one time. Then start at one corner and work your way around. By the time youre done with all four the paint has dried and you can start on your second coat going around the same way.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      10-24-2007, 11:24 AM   #9
mds82
mds82's Avatar
364
Drives: 2006 325xi
one coat of the brush on paint is all you need too!
      10-24-2007, 11:26 AM   #10
HyperM3
Drives: See Sig
True, but two coats dont hurt either. And the color gets a bit deeper and more solid looking. Plus, theres so much left in the can and your wheels are already off, seems like a waste not to use it.
13 HD FatBob
07 335i(gone)
      10-31-2007, 03:14 PM   #11
stejus
Drives: 2007 BWM 335i Coupe 6sp Alpine
I recommend G2 Caliper Paint. I used G2 paint on my previous car and after 5 years and 45000 miles; the calipers looked the same as the day I painted them. The kit cost about $36.00 and comes with a cleaner solvent, a brush, paint and a mixing agent to mix into paint. You must use the paint in 5 hours or else it will start to cure in the can.
      06-09-2009, 12:06 AM   #12
addicted2drums
addicted2drums's Avatar
Drives: e90
wow i am glad i found this post. i was going to take my caliper off and use some high heat spray paint. now i just need to find a store in so cal that carries the stuff.
"No matter what side of the argument you are on, you always find people on your side you wish were on the other." - Jascha Heifetz
      06-09-2009, 12:30 PM   #13
iAerodynamic
iAerodynamic's Avatar
Taiwan
116
Drives: 325i
2006 325i  [0.00]
what color would be suggested for a black e90 with black rims chrome lip?
      06-09-2009, 05:00 PM   #14
The English Hacker
The English Hacker's Avatar
Drives: 2006 BMW 330i / 2000 VW GTI
Depends if you want them to stand out or just look clean. For the former you could go with red, for the latter, black.
      06-14-2009, 12:29 PM   #15
MalM3
4 pot warrior
MalM3's Avatar
Drives: E90 318I
2006 e90  [10.00]
why didnt you take the caliper off , remove the brake block and squeel spring?
if the paint cures so hard, how easy is it going to be to take the spring off without peeling the paint off?
