BMW 3-Series (E90 E92) Forum
DIY: Fender Rolling
10-06-2007, 11:51 AM | #1 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
DIY: Fender Rolling
Ok, after a week of driving on my new apparently too wide shoes, I was tired of the rubbing. It wasnt happening all the time but it was a hassle to keep dodging bumps and grooves on a daily basis.
I finally found a place that had the eastwood fender roller around me. They let me borrow it for $30. I thought about investing in one for $200+ but figured I should attempt it first and see how it goes. Anyway, for all those that want to know, Im running 19x9.5 wheels in the rear with et30 and 275.30.19 General Exclaims. *-Denotes important safety point you dont want to skip over and I take no responsibility if you are an idiot. *First off, you need to be on flat ground. Youre going to be lifting up the rear and if youre on an incline, theres nothing to stop your front wheels from rolling. Please do not attempt this any further if you dont feel comfortable with this. Next you want to make sure you have two jackstands. I do not recommend using multiple boards of wood or bricks, youre just asking for trouble. Now you can go about removing the rear wheels in two different ways. You can loosen the nuts while the car is still on the ground, or you can do it while the car is up in the air. If you choose the latter, youll need to make sure the parking brake is on so the wheels dont spin. However, youll need the parking brake off in order for the tool to move back and forth. I find the first choice to be the more efficient and quicker. So, with the parking brake off and the rear lugs loosened, you want to slide your jack under the back of the car so that the pad is under the rear diff. *Be careful when jacking as you wont have that much room and you will hit your bumper if youre not careful-patience is a virtue here. Youll be doing incrimental pumps to get the car in the air and once its up a few inches youll be able to get the jack handle moving much better. Once the tires are cleanly off the ground, place the jackstands under the rear side jacking points of the car. Make sure that the jackstands are high enough so that when you lower the car, the tires dont rest back on the ground. *SLOWLY lower the jack so the car places itself correctly on the jackstands. You will hear creaking and moaning and more than likely the jackstands will move. DO NOT lower all the way, keep checking on the jackstands to make sure the car is placed properly on them. Once you have confirmed that, slowly lower the car until all the weight is on the jackstands. *Keep the jack firmly placed under the diff as a secondary safety precaution if the jackstands fail. Now remove the wheels and place the tool onto the hub. The tool I borrowed had a black ring inside that kept it from going onto the hub correctly. I just knocked it out with a flat head screwdriver. I then used my OEM lugs(only 4 of them) to hold the tool onto the hub. Best thing to do is inspect the inside of the wheel well to see where the tires may be rubbing the most. Youll want to do that so you know where to focus most of your rolling. *The hub rotates in a perfect circle, your wheel well doesnt. You do not want to run the roller back and forth along the whole wheel well. You want to do this in increments. I started from the factory indent in the front part of the wheel well. Make sure the roller is placed correctly in the middle and at the right angle. *Do not place intense pressure with the roller immediately. You want to start out slight and keep adding pressure gently. Do about 4 inches at a time and then move onto the next part. Its at this critical juncture that you may think to yourself "this is easy, and I can do the whole thing in a few swipes, 4 inches a time is too slow". STOP. This is not something you can rush, unless you like cracked paint or a dented out fender. You will see the fender pushing out as you keep applying pressure. You are doing two things here; flattening the inner lip, and actually moving the fender out. Because both things are happening at the same time, this is why you want to take your time. I was able to do both fenders in about 20 mins each. The whole job took about an hour(including jacking, removing wheels etc.). I honestly think this is how long you should spend on it every time you do it. This is not a job you can rush through or perfect in 5 mins by doing it multiple times. You will also notice that I didnt use a heat gun. While through all my research it seemed that it was a necessity, it was also 85°+ out and, well, I was just too lazy to go buy one. If you do it slow enough and careful enough you wont have any paint cracking issues. That being said, If I were to work on other peoples cars I would get one just for my insurance benefit. I saw one at Pepboys today for $19.99 so they arent wallet busters. Anyway, heres the order of the pics. 1. Jacking point at the rear under the diff 2. Jackstand placement once the car is lifted 3. The black center ring I popped out of the tool 4. A picture of the inside of the wheel well to show where I was hitting. I couldnt tell if the black stuff on the liner was just overspray from my tireshine or if I was actually hitting it. 5. Placement of the tool on the inner fender lip 6. What the inside looks like after youre done rolling. The lip should be vertical and you can see the liner folding in to meet it. 7. The little amount that the fender gets wider by from the outside 8. You can see from above how it fits the tire better If you have any questions or comments, feel free to post.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
10-06-2007, 11:52 AM | #2 |
342
Rep 6,188
Rest of the pics.
13 HD FatBob
10-06-2007, 12:04 PM | #3 |
Rep 3,106
Looks good, I have the same issue with my 265 with the same offset, and have been thinking of doing this for a while
Delivered 28 May
10-06-2007, 12:13 PM | #4 |
STEVIL Empire
218
Rep 6,297
Great write up!
Should make this a sticky so that anyone who wants to attempt this for themselves, will benefit from your experience. You left out the most important piece of info though.....did you eliminate all rubbing after you performed the fender rolling?
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
10-06-2007, 12:21 PM | #5 | |
342
Rep 6,188
Very happy now.
13 HD FatBob
10-06-2007, 12:56 PM | #6 |
Rep 6,664
Nice one hyper..
Do you have any before pics to compare the after to?
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
10-06-2007, 12:58 PM | #7 | |
342
Rep 6,188
EDIT: Just found a pic of the what the fender looked like before.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) Last edited by HyperM3; 10-06-2007 at 01:02 PM.. Reason: Found pic |
10-06-2007, 01:04 PM | #8 | |
Rep 6,664
Well, I'm about to head out to detail my car in a sec, so I'll take a look...
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. Last edited by Josh49; 10-06-2007 at 02:22 PM.. |
10-07-2007, 10:35 AM | #11 |
342
Rep 6,188
NOBODY carries this. You either buy it directly from Eastwood, or Tirerack. Im thinking about picking one up though and adding that to my repetoire of mods I can do for people.
13 HD FatBob
10-07-2007, 12:36 PM | #12 |
Rep 4,320
Drives: '07 Z4 M Coupe
awesome write-up and looks great.
10-10-2007, 10:53 AM | #13 |
Rep 2,875
Wait.....you said the fender got a little wider after rolling it? Then wouldn't the rear bumber not sit flush with the fender anymore now that the fender is wider? In the pix it shows that the bumper still sits flush w/ the fender......
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
10-10-2007, 11:00 AM | #14 |
342
Rep 6,188
Its not a "widebody" kit. You only need to roll the top of the fender thats hitting. The back of the fender where it meets the bumper is nowhere close to rubbing so you dont need to roll all the way back there.
13 HD FatBob
10-10-2007, 12:55 PM | #15 |
BK Employee of the month! / Moderator
636
Rep 15,795
Nice job Alex!
Sponsored by: Pics of the ---> Barbera Beast <--- Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America Matt@Camber-Toe (Like them on Facebook Camber-Toe) LuxAngelEyes (Like them on Facebook LuxAngelEyes) LTBMW (Like them on Facebook LTBMW) OEMconcepts (Like them on Facebook OEMconcepts) |
10-10-2007, 01:19 PM | #17 |
342
Rep 6,188
Thanks guys. Really means a lot.
13 HD FatBob
10-10-2007, 05:11 PM | #19 |
342
Rep 6,188
Where at? I may just have to pick one up and offer my services in the area.
13 HD FatBob
