F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > balancing/alignment after bbk install?
Extreme Powerhouse
      06-18-2013, 04:02 PM   #1
momo3605
Drives: M340i LCI, 718 GTS 4.0
Does one need balancing or an alignment after installing a bbk? What about new rims and tires?
      06-18-2013, 04:30 PM   #2
JMK007
Drives: 335 M Sport, RWD
Interesting question... At first blush, you would think the answer is no. However, I just had a BBK installed and my car was out of alignment afterward. I'm not sure how this happened but I know it was not out of alignment before the install.
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09
Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11
Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19
      06-18-2013, 04:51 PM   #3
momo3605
My car has been a bit bouncy/unstable feeling after installing my bbk, I'm not sure if it's placebo or if it is out of alignment
      06-18-2013, 06:14 PM   #4
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
I installed my mperf brakes and I can't see why you would need to. You don't touch any suspension components. MAYBE if you had a hard time w the front rotors but I think that's stretching it..
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      06-18-2013, 09:30 PM   #5
JMK007
The installer said the same thing you did; a bbk install would not cause an alignment problem. We checked the alignment after install and, sure enough, it was way off. The installer said I must have hit a pot hole before the install. Yeah, ok... The reality is my car drive dead straight before the install. After install, it pulled moderately to the right and the steering wheel was off to the right. Something happened during the install...whether it was a stuck rotor or something else.
      06-19-2013, 09:35 AM   #6
mikew2069
mikew2069's Avatar
413
Yea anything can happen. My rotors slid right off but if they were stuck a bit, they may have had to bang them with a mallet and that could cause an alignment issue...
BM3/H&R/Borla
f30post
