      03-17-2013, 05:35 PM   #1
Harveyten
Drives: M6 coupe
LED Fog Lights
LED Headlights are amazing however I would really like to change the foglight lamp to LED... The car has got adaptive lights and the Yellow foglight just does not look right any suggestions??
2014 M6 Coupe & 2013 X6 4.0d M Sport
Previous
2012 640d M Sport Convertible,2011-X5 4.0d M Sport,535d M Sport, 2010-M3,2009 335D M Sport, 2008 M3, 2006 X5 Le Mans, 2004 Z4 3.0, 323i first Luv
      03-21-2013, 10:59 AM   #2
polar993
Legend
41
Drives: 2017 Alpina B6 Gran Coupe
If you want LED fog lights, you need to find ones with Load Resistors built it, otherwise you will get an error message.
I learned this the “hard way”, though since the fog lights are so easy to change, it wasn’t a big deal to revert them back to stock.
I just bought a separate pair of load resistors that I plan to connect to the LED H11 fogs I bought, and I hope this gets rid of the error message.
I’ll post details of my results.
      03-22-2013, 10:31 AM   #3
TonySCV
Drives: '18 M3CP Santorini Blue, X3M40
The problem with LED fogs is that they have a very low power draw, and BMW also uses them as cornering lights. The Lights aren't true on/off because they also serve as cornering lights, they fade and dim, which will cause flickering and shorten the life of the bulb drastically unless the LED lights can handle dimming.
You'd be far better off finding a higher color temp halogen bulb (4000-6000k) and replacing it with that instead to match the look of the LED light. You'll need to experiment to find a color you like.
I went another route - I coded my car to disable the cornering lights altogether.
      03-25-2013, 02:21 AM   #4
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [2.83]
Just to be on the safe side and have less head ache go with the Halogen White Bulbs
      04-01-2013, 12:20 AM   #5
polar993
Legend
41
I just tried the load resistors with a set of H11 LEDs that I bought from CARid.com.
The load resistors were 50 watt ,6 ohm.
In installed them and the load resistors got incredibly hot within about 3 mins. They got so hot that even the positive and negative wires connecting them started to melt! Too dangerous to install!
For now, I just put the LED bulbs in and will deal with the warning light that says "bulb failure". I will be sure to check that they don't get overheated the next time I drive the car. If they do, I'll revert to stock, and go the halogen route.
Anyone else have any luck with LED fogs????
If so, please share!!!!
      04-01-2013, 03:09 AM   #6
Soft
Drives: Audi A7 3.0 TSFI
Anything like this will do:
http://www.flickr.com/photos/90792220@N04/8253163713/
Cree: powerful
Canbus: built in resistor, error free
      04-01-2013, 11:44 AM   #7
polar993
Legend
41
Cree: powerful
I assume you're referring to these Cree LEDs which claim to be error free with the use of the load resistors:
http://www.ebay.com/itm/2-H11-CREE-L...e58681&vxp=mtr
They probably will work the same as the Lumen LED bulbs I bought from CARID, which also claimed to be "error free" without even the use of the load resistors!
http://www.carid.com/universal-led-l...FY6e4Aod8E4Asw
I installed separate load resistors with the Lumen LED bulbs, and they look great, with no error codes, but the resistors got dangerously hot (as I posted previously).
Plus there is no good place to mount the resistors near the fog lights, unless you extend the wiring quite a bit.
Anyone else have any luck with LED fogs? They look amazing! Just wish the resistors didn't get so hot!
Anyone know if a different resistor would work? Something that will actually reduce the load on the resistor so it wouldn't get so hot?
      04-03-2013, 07:20 PM   #8
udmx6
Drives: X7, i3s
Don't buy cheap Chinese products
If you are interested in LED fog light, Bellof is good http://www.bellof.co.jp/products/led...b/boldray.html
or Nokya http://mtqinc.com/nokyausa/new.php
When I had LCI X6, I installed HID instead.
      04-03-2013, 08:42 PM   #9
mikikuki7
mikikuki7's Avatar
Drives: F15 50i
Talking
why isn't it easy to just purchase it? I have to translate from japanese to English and I can not find how to purchase it... >.<
Anyone knows where to find LED for X6's interior and brighter license plate?
      04-16-2013, 04:14 PM   #10
titanle
Drives: 2010 X6 Activehybrid
led foglights are kind of pointless IMO. I had them installed in my S550 and although they were extremely bright to look at, they didnt put much light out. LED are better suited as DRL, not as a functional foglight.
      05-10-2013, 12:58 PM   #11
Natural335
Natural335's Avatar
Drives: 2007 E90 335i AW/Terra 6sp
How about these.....
      05-10-2013, 08:01 PM   #12
mikikuki7
mikikuki7's Avatar
Drives: F15 50i
where did you find those?!?!?!?!!?!!!?
      05-13-2013, 10:32 AM   #13
Natural335
Natural335's Avatar
I know a guy.
They are for sale for the right price. As I do not have an X6
      05-13-2013, 02:09 PM   #14
Nicky P
Drives: M3 Saloon
Hi,
I also have an LCI in the same color with LED's. Can you confirm what HID is please and part number for the ones you have fitted.
Thanks
      05-18-2013, 02:01 AM   #15
polar993
Legend
41
What are those???
      05-18-2013, 01:20 PM   #16
makdeniss
Lord Vader
makdeniss's Avatar
Estonia
Drives: BMW X6
wowwww what is this?
My ugly illusions are such a beauty!
      05-29-2013, 09:27 AM   #17
Natural335
Natural335's Avatar
OEM LED Fogs from the new X6!!!
      05-29-2013, 11:51 AM   #18
1230vani
1230vani's Avatar
Drives: F15 30d Msport
Now this is crazy .
      05-30-2013, 04:22 AM   #19
makdeniss
Lord Vader
makdeniss's Avatar
Estonia
Drives: BMW X6
Probably x5 you mean...
      06-02-2013, 02:29 PM   #20
mikikuki7
mikikuki7's Avatar
Drives: F15 50i
here is a pic... of course, in person it looks much better!
      06-02-2013, 07:59 PM   #21
uplandswayx6
uplandswayx6's Avatar
Drives: 2011/11 BMW E71 X6 40D
Question
Good morning all,
New member here, just bought 2011/11 E71 X6 40d and ready to start mod`s !
I`m UK based and looking to change the Angel Eyes from the yellow yukk to a nice bright white - can anyone point in right direction.
Plus I`d like to change the lower fog lamp to match, I`ve heard Halogen is the way forward?
I understand its probably been done to death on here but thanks in advance.
We haven`t even picked the car up yet and already we have dealer/garage carrying out modifications - going for all stealth look.
Cheers and thanks.
uplandswayx6
      06-02-2013, 08:15 PM   #22
UltimateManga
Drives: M4 & X6
Hi mate and welcome to the forum, the best angel eyes are prob from ish on the forum i bought a set of 32w led angel eyes and recommend these highly as they look great and there only 100 delivered! Also for the foglights i chose a set of hoen xenon match fogs as these match the xenon headlights in colour and look great.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
