Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Changing Interior Trim - DIY
      11-23-2005, 04:16 PM   #1
325IAT
Lord Of The Fjords
325IAT's Avatar
Norway
38
Drives: 325i Coupe
2006 325iAT  [0.00]
2006 325iAT  [0.00]
I received my aluminum trim today and thought it would be hell to change my plastic aluminum trim to the real thing, but it was very easy. You just have to use power.
I started out with the door handles. They were the easiest to change. I used a flat screwdriver to lift up the outer end of the trim. I lifted it enough to get my finger under it. Then it's just to pull it slowly from one end to the other. Use power, but do it slowly. The trim will be released from the clips. I then put the new ones on. Very easy. This goes for all of the doors.
Now for the dash...
A bit more time consuming, but quite easy.
Use the flat screwdriver again and lift the right side of the trim (by the right door). The air ventilator will also come off. When you have reached the center of the dash (where the dual ventilators are) you need a torque key (size 10) to unscrew the two screws that holds the center ventilators to the trim. When they are unscrewed you work on the key hole. It's clipped on. Unclip it on the backside and take the outer part of the key "ring" and button out. The ventilators on the right side and in the middle is also cliped on the trim. Unclip them and you will release the whole trim panel. Reverse this order for putting the new trim on. The left side of the wheel is easier. Just do the same as above.
Now for the toughest part - The center console (non iDrive)
First you have to pull up the gear frame. It's easy, but you need to use a bit of power. When it's up you can take off the whole console (Don't forget to lift up the armrest). The you need to unscrew the four screws that holds the ashtray to the trim. When you're done, unclip the storage bin (by the armrest). Then you need to clip off the ashtray trim. Also, clips. To put on the new console, repeat what you just did.
I aslo changed the trim on my steering wheel. I had the same alu plastic trim, but wanted it black, so it would look better with the real aluminum. Use the torque (same size) to unscrew the three screws behind the wheel. The unclip the plastic trim. The controls will need to be unscrewed from the trim. Repeat the whole process to put on the new trim.
All in all I used around 1,5 hour. Next time I guess I can do the same thing in 30 minutes.
By the way, I have a complete plastic alu set for the E90 if anyone wants it cheap.
Good luck!
C
      11-23-2005, 05:39 PM   #2
speed_330i
Drives: 06 330i
thanks for the info, you should've took some pics too!
      11-24-2005, 09:34 AM   #3
bavarian19
bavarian19's Avatar
Drives: Car
post some before/after pics if you can...
      03-20-2006, 02:39 PM   #4
homerfromathens
homerfromathens's Avatar
Greece
Drives: saab convertible
pictures?
is somebody able to post pictures?
thx!
      04-10-2006, 10:51 AM   #5
prust
Drives: 330i
Trim Removal
Can you tell me more about replacing the center console trim? What is the gear frame? What are you pulling up? Any help with more details would be appreciated. Thanks.
Peter
1980 320i sport
1986 535i
1998 Z3
2000 323Ci
2003 540i sport
2006 330i
      04-11-2006, 10:05 PM   #6
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Pics please
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      10-24-2006, 08:34 PM   #7
StewtheBassman
Drives: 2011 X5d 421,000kms
I'm having a tough time with the gear frame. Everything else went perfectly.
      11-19-2006, 12:55 AM   #8
antidentite
Drives: See signature
Where did you get the aluminum trim, and how much did it cost?
Thanks.
Retired: '00 e46 (5mt)
Retired: '07 e92 (6mt)
Current: '08 S2000 (6mt)
Current: '17 Porsche Macan GTS
Current: '04 V8 4Runner
      11-25-2006, 11:13 PM   #9
carl_lazlo
Doctor of Journalism
carl_lazlo's Avatar
Drives: E 92 335i Sapphire Black
I'm getting delivery this week of a 335i coupe with coral red and dark burl walnut trim. I would like aluminum.
I have idrive.
How much for the trim itself?
      12-12-2006, 12:18 PM   #10
BigO1120
3rd Degree
BigO1120's Avatar
Drives: 2007 Montego Blue 328xi
      12-12-2006, 12:26 PM   #11
cm3rc
cm3rc's Avatar
Drives: 2006 E90
06 325i  [0.00]
nice write up. yet it would be nice enough to see some before and after pics.
      09-09-2007, 11:23 AM   #12
jzenil
Drives: BMW 330i
Trim removal pictures
      03-10-2008, 11:57 PM   #13
Kitz
Kitz's Avatar
Indonesia
75
Drives: ex BMW
thx for the pix...I'll be using this DIY soon..
      03-22-2008, 04:43 PM   #14
UdubBadger
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
it was a lot easier than I had thought... only had parts were 1. reinserting the wiring for the hazard lights by hand... that took about 10 min to slip it in there, they dont give you much room to work. and 2. popping off the ashtray cover without breaking any clips.
anyway heres a few pics from my install.
      03-22-2008, 05:21 PM   #15
hl0m4n
hl0m4n's Avatar
great diy
      03-31-2008, 12:46 AM   #16
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
so how do you remove the ashtray trim ?
      04-02-2008, 12:29 AM   #17
UdubBadger
2011 135i  [7.46]
2008 328xi  [8.76]
that one was a bitch to do. i dont even remember how its done but there is another DIY for interior trim... check that one out.
      04-02-2008, 06:20 PM   #18
mrvuml
mrvuml's Avatar
Drives: E90 335i w/ZSP
2008 335i Sedan  [0.00]
Its explained in the DIY for the Sunglasses tray mod.
      11-11-2008, 07:15 PM   #19
choopy
Juicy Booty NomNoMnom
choopy's Avatar
Drives: 04 M3 Vert/2005 M3 Competition
okey guys, so I just tried to remove my Trim and i followed the OP's directions, but i feel like im going to snap the vinyl. How much power is power?! I mean if someone could put it into perspective for me?
19" Monarch 410 Staggered || Matte Black Grill || 4" Exhaust Tips || Dual Intake || GP Tunders 7500K || Money Tints || JB2 ||Custom Start Button || Updated!
      11-15-2008, 10:51 AM   #20
oncastillo
Guatemala
Drives: E90 330Xi
nice simple writeup ....go badgers!!!!!!
      12-01-2009, 09:05 PM   #21
BimmerValeT
Drives: 2007 335i
any guide with i-drive?
      10-01-2010, 09:41 AM   #22
Justin7894
Drives: 2008 335i Sport
Can someone rehost the pics in this sticky, or add new ones for Trim removal?
Without the pics, the DIY is somewhat useless.
