BMW 3-Series (E90 E92) Forum
LCI climate control unit question???
02-09-2013, 02:53 PM | #1 |
Rep 195
Is the later type climate unit with the ALL and heated seat buttons a plug and play install into a 06/2009 car with the earlier REST button module. Will the heated seat wires plug straight into the later unit??
Thanks |
05-16-2013, 06:25 PM | #5 |
Rep 186
Drives: 07 E92 335i 6MT
05-16-2013, 08:00 PM | #6 |
Rep 314
Drives: 2006 325xi
I can confirm that it's plug and play, no coding required. You lose the REST function, but gain ALL to sync the dual climate control
The heated seat controls work, they duplicate the lower control buttons (both light up the same and seats work correctly regardless of which button you push). If you don't have an xi or other options such as the rear sunshade, you could replace the button panel with a blank cover |
05-16-2013, 09:05 PM | #7 |
Rep 186
09-09-2016, 02:30 PM | #9 | |
Rep 8
IHKA must be coded according the car or there will be a lot of errors and you will not be able to adjust flaps trough navigation. After coding you should change REST_TASTE_VERBAUT to nicht_aktiv and ALL button will become alive |
