06-17-2012, 04:15 AM | #1 |
Rep 379
Flat with runflats
Have any of you experienced a flat with the runflats?
Does it feel different to a conventional flat? In fact, did any of you have a flat and not realize it for awhile? LOL
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK 2012 F30 328i Sportline (Mineral Grey) |
06-17-2012, 04:31 AM | #2 |
Rep 174
Drives: M4 | X5 | Z1
Two years ago a had a flat rear wheel tire. Initially I did not even notice the difference, besides the car showing a warning. I pulled over to see what was wrong. Very hard to see the difference.
You can almost drive like normal with a flat. |
06-17-2012, 05:45 AM | #3 |
Rep 22
Yes. It's happened twice to me. I seem to have a knack for getting punctures! The good news is car handles exactly the same. The bad news of cause it that you can't repair the tyre even with a minor puncture because the act of driving on it writes it off. You are also only meant drive on a 'flat' for 250 km (155 miles) and at the same time also reduce your speed to 80 km/h (50 mph). It is really easy to forget about reducing your speed because the car doesn't handle any differently.
The only other thing I noticed was the tyre which was 'flat' got incredibly hot after driving only 30 km (19 miles), so hot that you if you had touched it it would burn you! |
06-17-2012, 07:28 AM | #4 |
Rep 5
I had a flat not too long ago. Only thing to tell you is the run flat warning in the car. Would not know which is one has problem until you pump in the air. So now I carry a pressure gauge in the car to check!
06-17-2012, 07:37 AM | #5 |
Rep 520
Drives: 2012 F30
Garage List 2012 BMW 328i [10.00]
(retired) 2009 528i [10.00] (retired) 2006 325i [10.00] (retired) 2002 325ci [10.00] |
You will never get stranded, but they are expensive!
2012 F30 328i, Melbourne Red, Premium, Sportline, Steptronic, Xenon, Harmon Kardon.
06-17-2012, 04:00 PM | #7 | |
101
Rep 1,237
06-20-2012, 05:19 PM | #10 |
Rep 262
Drives: 2012 BMW 328i
I had a screw in the tire of my F30 328i a few weeks ago. It was a slow leak and I never noticed a difference, even after the TPMS alarm went off. I drove slowly to a gas station, filled up with air (tire was at 25 psi), then drove home. The next day, the air was low again, about 25 psi, and took it to the dealer, where a screw was removed from the tire and, fortunately, repaired and not replaced.
06-20-2012, 05:22 PM | #11 |
Rep 262
06-20-2012, 08:31 PM | #12 |
Rep 385
Can the summer version of the same Pirelli be repaired?
07-05-2012, 05:43 PM | #13 |
Rep 262
07-10-2012, 12:04 PM | #14 |
Rep 122
What if you purchase the warranty the day you get the flat? Will it still work? My dealership let me buy it after the fact (25 days) and I now have a ruined tired. THe analytics will show the warning came up prior though I am assuming right?
08-15-2012, 05:37 AM | #15 |
Rep 79
As far as I know, RFTs are as repairable as any tubeless radial. The trouble is if you drive on it while flat you are consuming the "run flat" rated mileage. So I am assuming if you fix it as soon as the flat is detected, it should be ok. Please note however that any fix, even on a tubeless radial, be it a patch or a plug or both nullifies the speed rating of the tire.
08-24-2012, 11:06 AM | #16 |
Rep 601
very interesting.......I think I would rather have regular tires and a spare
It's not illegal. It's frowned upon, like masturbating on an airplane.
09-01-2012, 06:28 PM | #17 |
Rep 12
I bought my 328 on August 12th and I just had to have my passenger rear tire replaced this morning... $429 later... And that's with a discount they gave me because they felt bad!
Here's a picture of the bolt that somehow found it's way into my brand new tire... I'm now looking to buy a set of wheels with normal tires and store the stock ones for when I go to turn the car in! |
09-03-2012, 10:35 AM | #18 | |
Rep 93
09-03-2012, 10:42 AM | #19 | |
Rep 12
09-03-2012, 10:46 AM | #20 |
Rep 710
I had 3 tires and 2 wheels replaced by BMW on my 2009 335i. Thank God for wheel/tire insurance. But they said they could not fix the run flats. It was always a replacement.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi |
