BMW 3-Series (E90 E92) Forum
Anyone know what this light means?
06-15-2012, 05:02 PM | #1 |
Rep 1,016
Uploaded with ImageShack.us It only comes on when I shut the car off, then turns off when I open the door. There are no lights when the car is running. I checked my oil level and it said it was perfect. Any help would be greatly appreciated! Thanks!
Crimson Red e92 335i - H&R Premium Performance Coilovers, 19" AG m359's, Cobb AP, BMS DCI, AA CP/BOV, OEM Gloss Black Grills, M3 sideskirts
06-15-2012, 05:06 PM | #2 |
Rep 142
Engine oil below minimum level.
At the next opportunity top up with 1 litre engine oil, see Owner's Handbook. Unfortunately the is no dipstick to confirm this. Probably best to add a little oil and see if light goes away.
2008 BMW E93 328i Monaco blue/cream beige/walnut, ZSP, ZPP, ZCW, Step/paddles, BMW Performance exhaust, smartTOP.
Former BMWs:2000 E46 328i ZSP, Conforti shark injector, M68 wheels. 1976 2002, Weber carb, headers, Ansa sport exhaust, Kamei air dam and trunk spoiler. |
06-15-2012, 05:07 PM | #3 |
Rep 1,016
If I can't get BMW oil this weekend what would be a good substitute? Or should I just wait until Monday?
06-15-2012, 05:17 PM | #4 |
Rep 142
If its an emergency I would try to find castrol edge or syntec (preferably european formula) in 0W30 or 5W30. Hopefully someone with a little more knowledge than me will chime in.
At least call the dealer and speak with a SA and see what they recommend.
06-15-2012, 05:58 PM | #5 |
Rep 7,433
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
06-15-2012, 06:43 PM | #6 |
Rep 5,627
Before adding oil, check the level through the OBC (turn signal stalk switches) after the motor has warmed up and is still running. If you need a quart, you can use Mobil 1 0w40 (but not 5w30). Also, there should be a check control message if the level is down a quart or more.
Tom |
06-15-2012, 06:44 PM | #7 |
Rep 740
Drives: 2002 E46 ///M3
Location: Los Angeles/Woodland Hills/Thousand Oaks/ ***Santa Cruz***
check the quantity and I spoke with BMW they said the castrol synthetic 5w 30 (same thing that they use diff package)
06-15-2012, 07:07 PM | #8 |
Rep 142
It seems things have changed since I last used Castrol Edge for oil changes in my former e46.
The syntec line seems mostly to be merged with edge to be Edge with Syntec power technology. According to the product data sheet the 0w-30 and 5w-40 are approved replacements for BMW LL01: http://www.castrol.com/liveassets/bp..._Sept_2011.pdf Hope this doesn't add much to the confusion.
06-15-2012, 07:16 PM | #9 |
Rep 142
Maybe this is better info. Right from BMW:
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx http://cache.bmwusa.com/Pdf_2861cf6b...5-bf45db277fe8
06-15-2012, 07:52 PM | #10 |
Rep 5,538
06-15-2012, 08:05 PM | #11 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
the two most common BMW approved LL-01 engine oils for non M cars are:
1. Mobil 1 0W-40 European Formula 2. Castrol Edge with Syntec 0W-30 European Formula most autoparts stores will carry either or both, it's typically 8-9 dollars a qt.
06-15-2012, 08:10 PM | #12 | |
Rep 1,346
Pennzoil Platinum European Formula Ultra SAE 5W-30 isn't sold over the counter in the USA unless you go to a specialty retailer. Valvoline SynPower SAE 5W-30 is the wrong version: Only Synpower HST 5W-40/5W-30 have formal BMW LL-01 approval and I've never seen it sold OTC.
