BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - halogen to xenon error removal
      06-20-2007, 05:41 PM   #1
parachute
parachute
parachute's Avatar
96
Drives: BMW 335i Coupe
2011 335i  [0.00]
2006 325i  [0.00]
DIY
rememeber: I am not responsible if any damage occurs to your car.
price reduced to $180!
1- Screw relay onto hole behind bumper (hole is a plastic plate underneath headlight, where the arrow shows). this keeps the relay high and away from water (even when it is a water resistant relay).
2 - Connect fuse end to battery
3- Connect round connector to ground
4 - Disconnect pin #3 from headlight connector by applying pressure on the little hole above it with a needle
5 - Connect bmw pin from harness in the place of pin #3
6 - Connect original pin #3 to the last wire and tape it up
- remove original fog light and brake plastic piece that separate pins (so that the connector fits -very easy to do, look at the last picture, thats not the original fog light, it's for illustartion purposes)
- place foglight back in it's housing
- connect socket from harness to fog light
- connect 27w bulbs to the original fog light socket and adjust the fog light harness so that the bulbs are held onto the bumper facing towards the engine. (don't worry, they only turn on if you press the fog light button)
If you need to know how to do the initial swap of the lights refer to this thread: http://www.e90post.com/forums/showth...+halogen+xenon
335i Coupe - LeMans Blue
325i Sedan - Mystic Blue (Retired)
      06-21-2007, 01:30 PM   #2
Desi
Drives: 2014 435i M-Sport X-Drive
First of all, Parachute, you are THE MAN!
Secondly, my 323i did not come with OEM fogs. I just finished reading that entire 28 page thread in which you figured this out. Basically, my question is, if I wired this with the relay and added the fogs in line as you suggested, would it still work? What I mean to say is, if I add the foglights inline and add the housings to the bumper, will I be able to install xenons AND fogs (that light up with the headlights) without ANY error? If so, that is incredible!
      06-21-2007, 01:54 PM   #3
parachute
parachute
parachute's Avatar
96
2011 335i  [0.00]
2006 325i  [0.00]
yes Desi, in your case it works out even better now that I think about it. Because your car did not come with fogs. this is the perfect solution to add fogs and xenons to your car without the error. And unlike us with factory fogs, you don't need to have 2 extra hidden fog lights to fool the computer!!
      06-21-2007, 02:01 PM   #4
Desi
Awesome man! The two things I most regretted not getting in my car all tied up into one nice and easy mod! Dude, you are the MAN.
Euro Xenons: Ordered!
Fogs: Lemme see if I can find that old FS thread!
      11-10-2007, 09:50 PM   #5
E90 ANdy
Drives: SG E90 325i sport + idrive
Hey Parachute, I just got some projectors and NON-oem ballast. They are made by Osram. So yeah, i did the wiring and everything for the projector conversion 5+6 together and ground to 2. My HID's flicker really fast. They would work fine for about 10seconds and then do that.. Will your harness fix this? If so.. LET ME KNOW! thanks for your help
AIM me if you have it :: *******
      11-14-2007, 09:33 PM   #6
wutasi
wutasi's Avatar
Drives: AW '07 E90 328xi
If I can throw in a question as well for Parachute.
Will your harness leave the fog lights on all the time?
Let's say leaving the switch on
1) auto
2) parking light
      11-15-2007, 10:29 AM   #7
parachute
parachute
parachute's Avatar
96
2011 335i  [0.00]
2006 325i  [0.00]
I'm pretty sure it will solve your problem since my harness uses the power from the positive lead under your hood, unlike your current setup taking it from the footwell module.
1) auto
2) parking light
the fog lights go on when low beam goes on.
in auto mode, when low beam automatically turns on, so do the fog lights
in parking light mode, only angel eyes light up, no fog lights
you can also set up this harness so that the 2 27w bulbs provided turn on with the low beams and hide them behing your bumper with a housing i don't provide. and you will have OEM operation of all your lights ERROR FREE!
      11-15-2007, 04:07 PM   #8
E90 ANdy
i got my my xenons to stop flickering using capacitors 4700uF 35v. But have errors.... :/ What does this harness include? is it plug and play? or do i have to modify my harness to integrate this.
      11-15-2007, 04:10 PM   #9
parachute
parachute
parachute's Avatar
96
2011 335i  [0.00]
2006 325i  [0.00]
plug and play man, check the diy pictures above. everthing is explained there
      12-06-2007, 09:34 PM   #10
parachute
parachute
parachute's Avatar
96
2011 335i  [0.00]
2006 325i  [0.00]
picture of 1 harness
      12-06-2007, 10:54 PM   #11
alanchan
alanchan's Avatar
Drives: 2006 323i
thank you parachute,
the last picture explains alot better.
I think it starts to make sense now
so my question is do I take the blue color fog lamp plug from your hardware and plug directly into my fog lamps?
I don't need to worry about the existing fog lamp wiring, correct?
323i, Arctic metallic , Cream beige leatherette interior , Titanium matt trim , Premium , Auto , 18" style 189 sport wheels , 335i bumper + kidney grills, CF pillars, Chrome window trim package , LCI halogen.
      12-07-2007, 05:00 PM   #12
parachute
parachute
parachute's Avatar
96
2011 335i  [0.00]
2006 325i  [0.00]
correct!
      12-28-2007, 03:24 PM   #13
06-325
Drives: '06 E90 SG
Parachute,
will the foglights work with this harness? Thanks
      01-20-2008, 09:29 PM   #14
Excellence
G-STAR
Excellence's Avatar
200
Drives: E90 to A5
I made the exact same kit for my custom foglights.
Watch out for the fuse housing, it might melt if it gets too hot.
      01-20-2008, 11:34 PM   #15
alanchan
alanchan's Avatar
Drives: 2006 323i
If the fuse housing gets too hot, will it burn the electronics of the car?
I've noticed Parachute has a built-in fuse, will it help the over heating problem?
      01-20-2008, 11:40 PM   #16
Excellence
G-STAR
Excellence's Avatar
200
Drives: E90 to A5
The fuse will over heat in the housing if it gets too hot. If the fuse blows then everything wont work and all you need to do is replace it. I made custom housings for my fuses that ensure they don't over heat and melt anything else in the car.
I am not sure if the Parachute will overheat or not.
      01-21-2008, 02:33 AM   #17
alanchan
alanchan's Avatar
Drives: 2006 323i
I guess its best to have Parachute tell us the answer.
      01-21-2008, 02:43 AM   #18
Excellence
G-STAR
Excellence's Avatar
200
Drives: E90 to A5
My kit doesn't. I do not sell it though. It's a simple black box with everything built in. 8A fuse with a 10A relay that supports 12 lines. The relay is the most expensive thing.
For foglights make sure you use 35W, or 55W max. Don't go 100W bulbs.
      06-06-2008, 10:07 AM   #19
joebaggg
E60
joebaggg's Avatar
Drives: Black Attack
2006 E90  [0.00]
is there a way to set this up with resistors rather then the bulb? any help on this? i finally have time to install this kit i bought months ago but im not too fond of using the dummy bulbs
      07-27-2008, 12:42 PM   #20
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
what is the set up for this in comparison to the instructions above (im asuming reverse the connections between the dummy bulb and fog lights)? where can i find the housing to hide the bulb?
      07-31-2008, 04:00 PM   #21
parachute
parachute
parachute's Avatar
96
2011 335i  [0.00]
2006 325i  [0.00]
You got it right
and regarding the previous post from excellence, there's no such meltdown issue
      08-03-2008, 10:40 AM   #22
joebaggg
E60
joebaggg's Avatar
2006 E90  [0.00]
anyone experiment with resistors to replace those bulbs yet? id try it myself but i dont know which ones to use. does anyone know?
