Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > e92 window regulator veritcal adjustment
      03-23-2012, 11:55 PM   #1
laserpipes
Drives: wannabe
Does anyone have a diy to adjust an e92 window regulator? My driver side window is about an 1/2 an inch off and isn't sealing properly. I can tell that it's off as the log sits quite a bit lower than the passenger side window. the passenger window is dead quiet and solid. Driver's side window has some lateral play and it noisy at highway speed.
      03-24-2012, 12:02 AM   #2
lilh00kup
Drives: Alpine White 18 M3
Have a similar problem if I open my driver side window at highway speeds. Doesn't close properly and leave a small gap
      03-24-2012, 12:09 AM   #3
mike3000fl
Drives: 06 330i
try holding the switch full down or full up for awhile.
one of those starts a initialization procedure and it will be fine after.
google e90 window initialization or something like that.
actually here...http://www.justanswer.com/bmw/4nc2h-...90-window.html
heres another from a member here....http://www.m3post.com/forums/showthread.php?t=462100
http://forums.5series.net/topic/2581...ti-trap-reset/
      03-24-2012, 11:50 AM   #4
blingman
Drives: 3er
Thanks! just did this on my car and it worked!
      03-24-2012, 08:48 PM   #5
laserpipes
Drives: wannabe
Just tried the regulator reset and still can't get the window to roll up that extra 1/2 inch that it needs to. The automatic 1/4 inch movement on open and close works, but when the door is closed, i need the window to go up that little bit extra to close the gap.
Any other ideas?
      04-15-2012, 05:56 PM   #6
laserpipes
Drives: wannabe
bump....still not resolved.
      05-24-2012, 07:47 PM   #7
laserpipes
Drives: wannabe
bumpity bump
bumpity bump
      05-28-2012, 03:14 PM   #8
Kalud
Kalud's Avatar
24
Drives: e92 335i
I have that exact same issue also.
Did you have coding done ? Like something related to the FRM module. I suspect the issue occurs when programming the FRM module while the e92 door is opened (hence cracked open the 0.5 inch automatically), it resets the top position to that lower 0.5 inch. Just a though... I am still finding a solution on that one and will report back if I find one.
Tried once the Window Initialization reset (http://goo.gl/613MK) but it did help...
      06-14-2013, 09:03 PM   #9
J Lau
J Lau's Avatar
Drives: E46, E82 ,E89, G30
Need help too
