BMW 3-Series (E90 E92) Forum
Time to add some oil between changes
10-07-2011, 07:48 AM | #1 |
Rep 1,746
As we all know these cars need an extra 1/2 qrt to 1 qrt of oil between changes. It is time for my car. I'm 3.5k away from a free oil change for the 45k service so I am going to add a little oil to hold me over. What is the SAE synthetic blend? If I recall it is 5w-30 but I do not want to be mistaken. Also, what is the spec or something like that? What I am referring to is the other specification one has to check for oil such as if it runs LLAN-01 or other specs? Any help would be great, thank you.
10-07-2011, 07:54 AM | #2 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
It'll be in your owner's manual, and if not there, it's easy to search for online. You might also check the stickers under your hood. There is also an M-spec oil that is something like 5W-60 that many people prefer in place of the "standard" high-performance BMW synthetic (made by Castrol).
That said, my car has never needed oil between changes...but I only have 33K miles on it. Plus, I'd always change it every 7500 miles on my own nickel (although every change is on my nickel now that my maintenance has run out). I'd never go 15K miles before changing oil and filter, no matter what the manufacturer's recommendation is.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
10-07-2011, 09:44 AM | #4 |
Rep 1,746
The previous owner had it changed at a dealer every 5k. I do not know why he did that especially since he bought an extended maintenance which I'm taking advantage of. The car is at 41.5k and the next oil change is at 45k so I do not want to run the risk for how cheap a qrt of oil is compared to a new engine.
So I found this list in the DIY section, http://www.e90post.com/forums/showthread.php?t=478346. It clarifies that for US bimmers they need LL-01 oil. What gets me is the different SAEs. On this DIY, http://www.team-bhp.com/forum/techni...1-e92-e93.html, it says to use 5W30 BMW Oil or Mobil 1 0W40 oil or Castrol European Formula 0W30. I do see the Mobil 1 oil but I do not see the designated Castrol oil. As long as the Castrol is synthetic LL-01 0W30 will it be fine? |
10-07-2011, 09:53 AM | #5 |
Rep 166
if you are worried about using castrol synthetic or mobil 1 5w30 or 0W30/40, just go to the dealer and pick up a quart of oil with the overpriced 'BMW' stamp on it!
'08 335i Coupe / 6MT / Sport / Premium / Nav / Cold Weather Pkg / Space Gray / Black Dakota Leather & Aluminum Trim
'10 X3 SAV / Premium / Nav / Cold Weather Pkg / Alpine White / Sand Biege Nevada Leather / SAV Pkg |
10-07-2011, 10:36 AM | #7 |
Rep 13,122
If you are paying more 8 to 9 bucks
You are being ripped off.
Its about the same as any full synthetic you would buy off the shelf. Its basically Euro Spec Castrol. I actually think 8 bucks is kind of a rip but thats what you find full synthetic at pep boys or autozone at now. |
