BMW 3-Series (E90 E92) Forum
Highway speed vibration normal?
04-10-2011, 08:16 PM | #1 |
Rep 158
Hello
I just picked up my first BMW. It was preowned. When I go above 70, the car seems to vibrate a bit. Is this normal? Should the ride be stiff or silky smooth. I have a 335i 2010 without sport pkg. |
04-10-2011, 08:21 PM | #3 |
Rep 254
If they put new tires on it, check to see that they did a wheel alignment after doing so.
04-10-2011, 08:41 PM | #4 |
Rep 75
Is it vibrating, or is it tramlining a bit? These cars tend to do that, especially on grooved payment due to the tires. It gets especially noticeable on worn tires.
If it behaves slightly differently on different roads or different sections of the same freeway, it is probably tires/alignment (tramlining). |
04-10-2011, 08:43 PM | #5 |
Rep 540
could be a bent rim.
Upgrades: <Cobb V3, DCI, BMS downpipes, ER charge pipe, Forge DV, bbs ch-r, 30%tint all around, bmw performance exhaust, umnitza V4 angel eyes>.....Next upgrades (I would like):intercooler, BBK, turbo upgrade....etc....
04-11-2011, 05:14 AM | #13 |
Rep 753
I have a similar problem as well. Right at about 60 MPH the steering wheel starts vibrating. Was wondering if its normal? Seems like it's not.
2001 Chevy 2500HD Duramax
2003 VW Jetta TDI 2012 BMW F800GS 2024 BMW M2 BSM 6MT Carbon Package |
04-11-2011, 11:48 AM | #15 | |
Rep 286
Check tire balancing first. Should cost <$30 at any tire shop. |
04-11-2011, 01:56 PM | #16 |
Rep 741
if you feel the shaking the in the steering wheel then its likely the front wheels, which +2 will need to be check for bends and re-balancing.
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX] |
04-11-2011, 07:43 PM | #17 |
Rep 158
Thanks. I broughtnit in and it was 3 wheels that were not perfectly balanced. The rims were fine.
What happened was that the car was 20 months old with ONLY 8500 miles on it. I picked it up over the weekend with a good price and since itnwasnsitting around for long periods, the tires got flat spots on them. A rebalance seemed to correct the issue. |
