TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Replace Kidney Grilles - LCI E92 Coupe
      03-12-2011, 02:26 AM   #1
QLD
QLD's Avatar
44
Drives: 2010 LCI E92 - Mineral White
This is a brand new picture tutorial to show absolute beginners how to replace the kidney grilles on a 2011 BMW E92 Coupe.
Its simplicity is the key to success and the job can be done in less than 15 minutes.
It is compiled in PDF format so you can download and save to your PC or favourite portable device.
Cheers..
QLD
..sweet torquin' diesel!
      03-12-2011, 07:24 AM   #2
ENINTY
Drives: 2006 325i Sport
Thanks, but I just stick my fingers between the slats, push up on the tabs and pull the grill out with my other hand. No need to pull out the bumper cover.
Nice presentation BTW.
      03-12-2011, 06:02 PM   #3
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
810
Drives: a black car
That only works on E90s - the slates are too narrow on the E92 so you have to reach in behind it.
      03-13-2011, 03:21 AM   #4
QLD
QLD's Avatar
44
Thanks for the feedback - can you share with us which 2011 BMW you did this method on?
It doesn't work for the 2011 LCI E92, that this DIY is for.
Cheers
      03-21-2011, 08:58 PM   #5
99three
Drives: 993, e92, e36, F355, Z32, Jag
Any spark plug threads?
      03-27-2011, 03:47 AM   #6
QLD
QLD's Avatar
44
If the question is directed at me???? NO.
      04-16-2011, 02:15 AM   #7
reddemon73
reddemon73's Avatar
Drives: 2014 BMW 435
Just put on my polished grills tonight. Thanks for the DYI. Very helpful. Took me a total of 10min after I figure out the tabs on the grills
2014 435i M Sport //AW, CR//premium, tech, lightening pkgs//20% tint//full clear bra//ppk//blk grills//20" Vertini wheels//digital gauge//Apple Carplay//MPE with catted DP//VSRF charge pipe//Wagner FMIC//
      04-26-2011, 07:09 PM   #8
QLD
QLD's Avatar
44
You're very welcome... glad it assisted you
      05-11-2011, 06:17 PM   #9
bigjilm
Drives: '11 335i Sedan
I used a combination of "fingers through the slats" and accessing from the back on my E90 (2011) and it was an easy job. 10 mins tops, and I could probably do it in 5 next time.
Thanks for the advice - you saved me a bunch of work.
      05-20-2011, 05:10 AM   #10
QLD
QLD's Avatar
44
No worries my friend - glad it helped you
      05-22-2011, 11:00 PM   #11
335hype
335hype's Avatar
Drives: 335i Coupe
great write-up bro, removing the (4) t-30s made the job so easy, can't see why everyone doesn't do it this way...thanks!
335i | coupe | 6mt | premium | sport | brushed aluminum | space gray
      06-09-2011, 07:35 AM   #12
QLD
QLD's Avatar
44
Glad it helped you br0..
      06-11-2011, 11:23 AM   #13
Rivenscyr
Australia
25
Drives: muzza-tastic cruiser
great DIY guide
Thanks for creating
      10-06-2011, 02:02 AM   #14
QLD
QLD's Avatar
44
Glad it helped
      10-20-2011, 12:10 AM   #15
edwarde92
Drives: 13' 535i
it helps a lot! thanks man
      11-10-2011, 05:45 PM   #16
QLD
QLD's Avatar
44
You're very welcome
      11-29-2011, 08:47 AM   #17
luster
Drives: e90, e88
nice one mate!
      11-29-2011, 03:48 PM   #18
xabo
Drives: '07 335i Convertible (Wife's)
Will this process work on E93 convertible?
      11-30-2011, 01:39 AM   #19
QLD
QLD's Avatar
44
If its an LCI - I can't see why not..
      12-01-2011, 01:58 AM   #20
worktolivelife
Drives: Mine
Just did mine E93, as per the great guide thank you (BMW dealership Sytners quoted £184 just for labour I can only imagine they were going to remove the whole bumper or maybe not!
      12-04-2011, 05:29 AM   #21
luster
Drives: e90, e88
hey mate
I had trouble opening your file on my mac, had to use Pdf Writer to see the text in your boxes.
I have converted it and made it mac compatible, I hope this helps someone
File Type: pdf Replace.Grilles.LCI.E92.by.QLD.fixed-by.luster.pdf (2.35 MB, 779 views)
      12-05-2011, 04:24 AM   #22
QLD
QLD's Avatar
44
br0.. there is nothing wrong with the file - you just have to have a resonably new version of a PDF program... FoxitPDF is best.. or Adobe... or as you used PDF Writer... the file is fine.
