BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - Hidden NonOEM Garage Door Opener Install
      03-01-2007, 01:48 PM   #1
robray
Drives: 325i
I couldn't justify the price of the rearview mirror with UGDO, so I hardwired a universal door opener I got for $30.
I installed the push button switch in the ashtray, in case I ever want to put it back to stock, the ashtray is a cheap item to replace. It got kind of late so, I forgot to take pictures. Here is the basic idea of what I did and the pictures that I did take.
1. Solder wires to the garage door opener switch and power terminals. I used terminal block connectors, so I can easily disconnect everything. This part will vary depending on your garage door opener. You could leave the battery in the door opener and not hardwire the power.
2. Remove the centre console. Instructions can be found here. http://e90post.com/forums/showthread.php?t=7049
3. Remove the panel under the glove box by taking out the two torx screws.
4. Run the wires for the power/ground and the switch from the centre console to the passenger side foot well. Connect the wire block connectors to the wires.
5. Splice the power and ground wire to the ashtray power plug. The connector has three wires and can be disconnected so the centre console trim and ashtray can be removed. I spliced it to the connector side that is left behind. Use a DVM to determine power and ground. Sorry, I forgot to take pics.
6. Stash the garage door opener on the passenger side of the car behind the panel under the glove box. I didn't need anything to hold it on place. It slid in tightly and will not move. (Note. You will obviously not get the same range with the door opener placed under the dash. I did notice reduced range, but I still have sufficient range to open the door before I drive up to the garage. You should test placement of you door opener before picking a permanent spot.)
7. Remove the ashray and drill a hole for the switch. I needed to drill a 9/16" hole. Using a glue gun, glue the switch in to place.
8. Connect the power and switch wiring to the garage door opener. Connect the wiring to the ashtray switch. Turn on the car and test the opener.
9. Tie up the wires with some tie straps. Re-install the panel and console and you are done!
      03-01-2007, 01:56 PM   #2
3thirty5
3thirty5's Avatar
Drives: 2014 BMW M5
2014 BMW M5  [0.00]
thanks for the nice write up, and a very good idea! think i'm gonna attempt that!
      03-01-2007, 02:11 PM   #3
canucklion
pull my finger to get your kinder® surprise
canucklion's Avatar
Drives: circles around you
this should be sticky'd!
thanks for sharing
      03-01-2007, 10:24 PM   #4
ages944
ages944's Avatar
Poland
99
Drives: E90 325i
damn good mod! I think I just found my next project.
BMW : Sine qua non
Mods: Blacklines | Rear Seat Power Outlets | Rear Fog Lights | Ashtray Garage Door Opener
      03-02-2007, 03:57 PM   #5
GregL
GregL's Avatar
Drives: 2016 CLA45 AMG
Thats pretty sneaky, very good write-up! I remember reading that thieves now might break into a car to take the door opener (which is commonly clipped to the visor), along with insurance/registration papers commonly found in the glovebox, then go to the person's home and see if there is a door leading into the house from the garage.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone
2010 Mercedes-Benz C350 4Matic - Gone
2006 BMW 330xi - Gone
2001 Infiniti QX4 - Gone
      03-02-2007, 09:04 PM   #6
200Duece
200Duece's Avatar
45
Drives: '73 2002,'18 X5 35d,'17 328d T
Could this work with for the Procede remote that is coming?
      03-02-2007, 10:26 PM   #7
jonerik26
jonerik26's Avatar
Philippines
58
Drives: black 335i e90 PRE-LCI
2007 335i  [8.00]
1998 Acura Integra  [8.50]
2006 325i  [8.00]
cool, that's pretty nice....i miss the universal garage door opener that i had in my 325i
      03-03-2007, 03:06 AM   #8
robray
Drives: 325i
Thanks for the compliments. I use it everyday and it works great.
Originally Posted by KT9 View Post
Do you have instructions for a 3 button transmitter?
My three button remote was stolen before I could figure out what the other two buttons were for. I am sure you could fit three switches in the ashtray.
I don't ever keep the remote in my car anymore and I keep a copy of my papers in my trunk. I am a little paranoid, but my original 3 button remote was stolen along with my insurance papers and my manuals from my old 330ci. Luckily they didn't get in the garage. Vancouver is really bad for auto theft.
This mod should work for any remote that has a button you can press. You just need to open it up and solder some wires to the button. What is a Procede remote?
      03-03-2007, 03:16 AM   #9
cm3rc
cm3rc's Avatar
Drives: 2006 E90
06 325i  [0.00]
haha nice write up
      03-06-2007, 01:23 PM   #10
HyperM3
Too many Alex's, from now on, call me Beaufort
Drives: See Sig
I did something like that on my M3.
http://hometown.aol.com/hyperm3/Dooropener.html
If anyone wants another way of doing it.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      03-06-2007, 07:36 PM   #11
mmm def
mmm def's Avatar
144
Drives: 21 330, 19 ND2 RF, 11 RX350
Wow i was thinking who cares until I saw your work, real nice job, thanks!
      03-07-2007, 12:44 AM   #12
xdrive
Drives: 330xi
Instead of making your own button, can't you wire it to one of these empty buttons? I'm thinking of doing this. Do-able?
      03-07-2007, 12:55 AM   #13
ages944
ages944's Avatar
Poland
99
Drives: E90 325i
I don't have the sunshade, only the heated seats. Hence, no row of buttons. But yeah, if you've got the buttons, that would likely work very well if you can tap into them easily.
BMW : Sine qua non
      03-07-2007, 01:13 AM   #14
robray
Drives: 325i
I like the idea of wiring the door opener to an unused button. I was looking for a button, but couldn't find one. Anyone know the part number for the button set in Xdrive's post? Been searching realoem, but no luck.
      03-07-2007, 05:31 AM   #15
Paul330d
Torque junky
Paul330d's Avatar
France
115
Drives: Remapped e90 330d
2006 330d  [0.00]
2005 Fiat Panda 4x4  [0.00]
Hard wiring the remote behind one of those blank buttons (next to the rear blind button) is very appealing. I wonder if you can order a push-button version to slip in there somehow? One with a little garage door logo on it would be the dog's b*llocks
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
      03-13-2007, 01:08 AM   #16
ages944
ages944's Avatar
Poland
99
Drives: E90 325i
Modified Installation
Was so inspired by the OP's work that I decided to do this myself!
- For my version, I made a couple of changes (pics included)
1. I used snap connectors between the run wire/ashtray, and b/w the run wire/garage door opener, so both the ashtray and garage door opener are completely removable.
2. I located the garage door opener in the center console, under the rubber tray in the armrest storage compartment. This gives me easy access to the battery on the opener, so I did not need to hardwire into the car's power supply. Secondly, I can also still activate the opener if the switch in the ashtray were ever to fail.
3. I also very much like knowing that I can return the car completely stock for the price of the ashtray insert.
The Pics: (sorry, didn't take any during construction)
1. The completed ashtray
2. View of the Run Wire on the Ashtray End with ashtray disconnected.
3. View of ashtray wiring
4. Remote is under the tray
5. Rubber Tray and Garage Door Opener Battery Cover removed, showing battery
BMW : Sine qua non
      03-15-2007, 11:50 AM   #17
Paul330d
Torque junky
Paul330d's Avatar
France
115
2006 330d  [0.00]
Good job! Has the range been affected by your 'hiding' the remote away in the centre console?
      03-15-2007, 09:16 PM   #18
ages944
ages944's Avatar
Poland
99
Drives: E90 325i
If anything, it's been improved, as there's less metal directly in the way of the transmitter. I can actually open the door from the street now, whereas before I had to be in the driveway and wait for the door to open.
BMW : Sine qua non
      03-17-2007, 09:48 AM   #19
acizek
acizek's Avatar
78
Drives: F90 M5, G30 M550d, F01 750i
2005 330d  [0.00]
great mod, really tempted to do this
      03-17-2007, 09:51 AM   #20
bavarian19
bavarian19's Avatar
Drives: Car
If you have the premium package, there is no need for this mod... just train your UGDO in your mirror... It works like a charm...
      03-17-2007, 07:34 PM   #21
khoda355
Drives: EG hatch/ E90
yah i have that but its soo had to train it to work.. still have not done it yet.. any help on how to??
      03-17-2007, 09:30 PM   #22
ages944
ages944's Avatar
Poland
99
Drives: E90 325i
Lol, of course he's right.
... however, I spent about about $50 on this mod ($40 of which was buying a new garage door opener). How much did you spend on the Premium Pkg? (tongue firmly in cheek)
BMW : Sine qua non
