BMW 3-Series (E90 E92) Forum
HELP - BMW Audio Cutting Out
10-20-2010, 05:33 AM | #1 |
Rep 21
Hi Guys,
The audio system on my 325i E90 started to cut out today (I was half way through a 3hr drive)... Basically all audio (radio, CD, CD stacker, Bluetooth) started to only work intermitently - kind of like a cable was loose... Another thing is the CD stacker stopped working and allowing me to select a CD or track; and the Bluetooth (phone) stopped allowing me to see my paired phone and make calls! argghhh I thought it may have been the Amp overheating, although I left the car for a few hours and it is still malfunctioning... It is the Logic 7 BMW Professional Audio system... Any help or advice would be GREATLY appreciated!! Thankyou SLC |
10-23-2010, 07:02 AM | #6 |
Rep 3,969
10-26-2010, 03:53 AM | #7 |
Rep 21
UPDATE: So for all those playing along at home it has been diagnosed as a faulty bluetooth phone module (the one located in the boot under the floor)...
I thought i'd buy a new module on the net, but I cannot seem to work out the correct part number! Any help would be greatly appreciated, the last 7 digits of the VIN are NB26517 and I have the SA 644 (Prep for mobile phone with bluetooth) in the car... The part number of the broken module is: 84.21 6-975173-02 - although I cannot seem to find this number anywhere on the NET.... HELP PLEEAAASSSEE |
12-22-2010, 10:56 AM | #8 | |
Rep 341
Drives: G01 M40i
Hello,
Was your dealer able to diagnose it specifically to the bluetooth module? I'm having similar observations too (though I think it's my battery going bad) but my dealer could not diagnose it to any equipment or cable issue. Quote:
2021 G01 M40i Glacier Silver
2020 G05 4.0 Phytonic Blue (Wife's) Retired: '15 F80 DCT (ED), '10 X5 3.0, '07 328i E92 |
12-22-2010, 03:51 PM | #9 |
Rep 21
yeah, he was able to trace it back to the bt module - he mentioned they had the diagnostic equipment to do this... I have just re-ordered a bt module so will let you know if it absolutely fixes the problem! Good luck!
12-22-2010, 05:44 PM | #10 |
Rep 21
So happy to report that the new bt module fixed the problem! Found the part number on realoem.com
Good luck! |
09-15-2015, 07:23 AM | #11 |
Rep 179
Drives: 2006 BMW 330i
digging this up from the grave as I have a similar problem.
radio, CD, and AUX audio cut in and out. Bluetooth does the same thing, but still pairs and works with my phone. Am I looking at an amp issue or Bluetooth issue?? |
12-01-2015, 09:37 PM | #12 |
Rep 73
Similar problem here. Seems like my left channel is cuting out, then if I turn up the volume over ~50% its back. I can then turn back down and it stays on for a while. Seems to be with radio and Aux, same issue. Not sure if thats the amp or radio? I do have the MOST setup.
