BMW 3-Series (E90 E92) Forum
335i RWD SEDAN on the snow ???
07-19-2010, 10:20 PM | #2 |
Rep 10,309
Drives: A///MERICAN!!!
They are fine with snow tires. Blizzaks or Wintersports are most acclaimed.
07-19-2010, 10:24 PM | #3 |
Moderator
618
Rep 10,858
Fine with snows, great with LSD.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
07-20-2010, 12:40 AM | #4 |
Rep 2,556
Not so good in the mountains even with snow tires and a lsd.
Probably fine in NY with snow tires. Get a set of used 17" wheels, or cheap wheels, and mount a set of dedicated snow tires.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
07-20-2010, 06:50 AM | #5 |
Rep 4,703
For NY you need snow tires, not just for snow but also for the cold temps.
Take your time and take it easy on the throttle and you will be just fine. |
07-20-2010, 07:56 AM | #7 |
Rep 80
I've taken my e90 335i with Wintersports skiing to Vermont and the Catskills several times. Only got stuck in the snow once, and that was in 8-10 inches of fresh powder. Definately took my time driving though.
07-20-2010, 09:28 AM | #8 |
Rep 939
18" Snows and it drives like a truck with 225 series Dunlop Wintersport 3D tires.
I went through 10" of snow with now LSD...
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
07-20-2010, 09:36 AM | #9 |
Rep 201
Would someone please recommend some decent (but cheap) wheels for dedicated snow tires? Exact part number from a vendor would be nice.
I've also got a 335i which will need snow tires before this November. |
07-20-2010, 09:40 AM | #10 |
Rep 10,309
My uncle runs Borbets on his E90 330, but any cheap wheel should be fine as long as it clears the brakes, like ASA too perhaps.
07-20-2010, 09:59 AM | #11 | |
Smiling Politely
1383
Rep 29,118
drive backwards, instant fwd
07-20-2010, 10:09 AM | #13 |
Rep 345
TireRack's a super vendor, esp if you're in the US. I run 17x8 Rials with Blizzak LMs from TireRack. They're competent in the winter stuff, but still suck on hills relative to FWD and AWD with fresh snow, slush or ice on the ground. With an SUV as the second family car and no daily commutes we get by.
07-20-2010, 10:15 AM | #14 |
Rep 10,309
FWIW in low grip conditions like snow sometimes it's best to turn off DSC/DTC, sometimes wheelspin is necessary to start going or keep momentum on hills
07-20-2010, 10:27 AM | #15 |
Rep 272
I use my 335xi as my winter car. I've got a set of Blizzaks and rims purchased from Tire Rack. They came mounted and balanced with TPS installed. The rims were closeouts and only cost $60 each. I drove through 6-8" of fresh snow without any problem. I did have to leave it home when the 20" snowfalls occurred (3 x's)
Rich
'96 911 C4 Cab (276,000 1 owner smiles) '11 X3 35i Black Sapphire/Beige,SAP, CP, CWP, DHP, PREM, TECH, Sat radio, Hi Fi, BMW apps, smartphone, 19" w/mixed performance tires. |
07-20-2010, 10:52 AM | #16 |
Resident Diesel Junkie
56
Rep 1,070
I drove my 335d through the record snowfalls this past winter without incident. I think that was partly due to the Continental DWS tires I have mounted, but the RWD is still more than capable of traversing through some serious winter conditions. In my experience, the ground clearance is more a limiting factor than the RWD.
07-20-2010, 10:55 AM | #17 |
Rep 6,318
put a spare wheel in the trunk in winter if you dont need the space. extra pounds will be useful and add traction a bit. You talking 50-60lbs extra weight over rear wheels. nice.
F30.F11.E86.E90.E90.E36 |
07-20-2010, 11:00 AM | #18 |
30
Rep 373
I've never owned a FWD car, except for my last car (2010 Mazda3) which was awesome to drive, but I still feel waaaay more comfortable with a 50/50 weight balanced RWD car and snow tires.
With DSC, even an average driver can drive these cars well in the snow as long as s\he has a set of decent snow tires. |
07-20-2010, 11:17 AM | #19 | |
Rep 1,391
Everyone experiences are all different, if you ask someone from Seattle like myself, driving in the snow around 32 degree, up/down steep hill would be different than midwest where temp dip to teen and flat geographic. If eskimo can have many words for snow flakes I can only imagine that many different driving condition in the snow. If you have to drive in the snow only AWD with snow tires will get you around safely, else we need to take car mfg that makes AWD as fraud. |
07-20-2010, 12:51 PM | #20 |
Rep 543
I live in Cincinnati, Ohio. Terrain here is a mixture of flat and hilly. Winters are rather unpredictable but we generally get a few large snowfalls and temps can get down to single digits. I'm considering either RWD with snow tires. or AWD with all-season. (Also keep in mind I live in a condo and don't have a garage to store tires. I'd have to keep them at a friends so that also factors into my decision.)
07-20-2010, 01:41 PM | #21 | |
Rep 10,309
For example: -stack all 4 in the corner and put a plant on top -arrange in a square or rectangle + piece of wood = coffee table |
07-20-2010, 01:44 PM | #22 |
No one can defeat the quad laser.
Rep 50
