Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - blackout "shadow" (black) kidney grills
      08-28-2005, 05:21 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Tools/Parts/Supplies:
- Torx-20 screwdriver
- 220 grit sandpaper
- 230 grit sandpaper
- 400 grit sandpaper
- Black paint (any black paint suitable for exterior use - get flat or gloss depending on desired finish)
- Clearcoat (not pictured here, but you should probably clearcoat the paint with a few layers as it will leave the paint less prone to chipping)
Removing Grills:
1) pop open hood
2) to remove top two grill pieces (the two pieces that are attached to the hood), remove all 6 torx screws using a Torx-20 screwdriver (as diagramed below)
3) to remove the two main grill pieces, grab a hold of 2-3 slats with each hand and pull out straight towards you (as diagramed below). The attachment points for the grill is shown below.
Sanding and Painting:
4) separate the chrome trim from the slats by lifting the tabs that connect the pieces and pulling the parts apart (see picture). This eliminates the hassle of having to tape up the slats (note: If you have a 325, using the bumper trim paint I used will result in a finish that is very close to the plastic finish of the slats, so no real need to also paint the slats; therefore it's easier just to remove and paint the chrome trim pieces. However, if you have a 330, you may consider keeping the entire grill (slats and chrome trim) together since you will be sanding and painting both the slats and the chrome trim.)
5) using the coarsest grit sandpaper (220), sand the surfaces you will be painting. The chrome should begin to turn into a coarse and scratched aluminum piece. Continue sanding with the next coarsest sandpaper (320) and finish with the (400) grit sandpaper. The final piece should resemble the brushed aluminum trim you can order with the E90 (see picture).
6) paint each piece using a total of 2-4 light layers so as to prevent dripping and uneven coverage. Wait a few minutes between layers to allow some drying between layers.
7) finish with a coat of clearcoat spray (I personally didn't clear coat because I liked the flat/matte look), but a coat of clearcoat shouldn't add too much shine and will add an extra layer of protection.
8) reinstall parts the same way they were removed.
VOILA!
Before:
After:
Blackout grills on richp's black e90
      08-28-2005, 09:42 PM   #2
tima
Custom User Title
tima's Avatar
Drives: 330i ZSP/TiAg/Blk
I don't think I'll do this on my TiAg, but the write-up is most excellent!!
tima
get off the phone and drive
      08-28-2005, 09:48 PM   #3
Ed_330i
Ed_330i's Avatar
58
Drives: 2006 330i
looks cool on black.
      08-29-2005, 01:47 AM   #4
JRMillion
Drives: 2006 330i
The Black one looks hot.
I am picking up my Black/Black 330i this week.
I would like to do this to all the chrome trim (front and sides) but I would be worried about screwing it up...
      08-29-2005, 06:18 AM   #5
scottz5
Drives: 13 F10 535xi & 11.75 E93 M3
GREAT DYI!
13 F10 535xi JB/B working on it
11.75 E93 M3 MR/Black Stock (wifey)
11 F10 535i AW/CB Mods Gone
      08-29-2005, 07:25 AM   #6
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Have you considered swapping all your chrome pieces with a 325 owner's black pieces? I'm sure there would be plenty of members interested in swapping with you. Might be easier than sanding/painting each and every last chrome piece.
      08-29-2005, 07:31 AM   #7
YYdoodle
Drives: E92 M3 fanatic
All DYI's should be this detailed
      08-29-2005, 10:16 AM   #8
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
Hey Jwocky....that was awesome! How much do you charge?
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      08-29-2005, 10:30 AM   #9
StewtheBassman
Drives: 2011 X5d 421,000kms
On my Jet Black this would look nice...with tinting...I knew some great E90 cosmetics would come along, this is fun.
      08-29-2005, 10:33 AM   #10
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Pro bono It's a fairly straight forward DYI, but if anyone in the NYC area ever needs help doing this, I'd be glad to assist.
      08-29-2005, 01:00 PM   #11
longtran
longtran's Avatar
1433
Drives: E90 M3
2006 325i  [0.00]
another great detailed DIY
      09-07-2005, 08:33 AM   #12
jdeads
Moving Up
jdeads's Avatar
Drives: 2005 E46 325i
But what about the chrome pieces at the tope of the grill? Aren't they attached to the hood? What's the best way to go about removing those without damage?
      09-07-2005, 11:43 AM   #13
exclusivo
exclusivo's Avatar
126
Drives: race car
uhhh, seems to me that part was covered in the first step. get a torx 20 screwdriver and unscrew it
      09-07-2005, 10:17 PM   #14
jdeads
Moving Up
jdeads's Avatar
Oh, I wasn't paying attention. Thought the screws were for removing the grill itself. Guess i'll look twice before asking next time.
      09-08-2005, 01:03 PM   #15
adam8
Drives: 325i
when your seperating the chrome trim the tabs break off pretty easily, so be careful with them. I think i broke two off (one from each) but they still went back together easily. Thanks to your diy i had no difficulties with this mod. thanks!!!!
      09-08-2005, 08:32 PM   #16
kelvinso
kelvinso's Avatar
22
Drives: BMW 320i E90 TiAg/Lemon
Look very cools on Black and thanks for the detailed instruction!!
      09-26-2005, 06:03 PM   #17
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
wow that looks great on black!
Nikki
      09-26-2005, 07:06 PM   #18
n21k
n21k's Avatar
Drives: E90 325i
2005 E90 325i  [0.00]
1999 E46 320i  [0.00]
looks great on black. Any SG with blackout kidney grills?
      10-18-2005, 06:57 PM   #19
Mafia_R7
Drives: '05 Gallardo
Its coming soon....
      10-20-2005, 01:09 AM   #20
BMW_E90
BMW_E90's Avatar
57
Drives: 325i
where can i get a extra grill, because i want to keep the original part in perfect condition. and how much would it cost?
      11-03-2005, 10:21 PM   #21
redv
Drives: hot carl e36
Wow.. makes the front end of the e90 look 100 times better.
I have a pair of extra grills for sale if anyone is interested so you don't have to mess up the ones on your car.
http://www.e90post.com/forums/showthread.php?p=80152
baller ass e36.
      11-03-2005, 10:30 PM   #22
tiga901
tiga901's Avatar
Drives: e90 330i, mt pp sp
One of the best DIY writeup. Very detailed instructions!!!!
