TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > E90 5.1 EQ setting for stero
      08-25-2005, 10:47 AM   #1
jlr
Drives: 2006 33i
My new 330i has the 5.1 stereo option. When I got the car I adjusted the base and trebble to higher levels but the stereo was noting special. A few days later I found equilzer setttings for the stero. When making the settings the frequencey chart displayed should look like a
V. The base and trebble (on the two ends of the spectrum), shold be
set hight while the center frequencys need to be at mid range. My
car came from the factory in the N postion. The comlplete oposite of what it sould be. I changed it to the v position and it sounds 100 percent bettter. Better than any sound system I have ever heard. When you get to the EQ mode the display should look like the below
---------------------------------------------max
------------------------------------------0
      08-25-2005, 10:52 AM   #2
RichReg
RichReg's Avatar
Drives: 2015 435Xi GC & 2000 323Ci.
Yep, you're absolutely correct.
The settings from the factory are flat, but of course you can adjust them to your own preferences, and then it WILL sound a whole lot better.
      08-25-2005, 12:20 PM   #3
MonacoBlueNJ
Drives: Monaco Blue 330i
In a normal stereo, the EQ flat should sound the best. My e90 has yet to arrive, so I can't really comment specifically on this stereo. Usually your radio will sound 100x better if you just leave the EQ alone.
      08-25-2005, 12:26 PM   #4
Jeffelite
Drives: 335xi Coupe
My salesman set the EQ for me, thankfully, and he did it exactly how you described. I think it sounds quite impressive.
330i Tit Silver, PP, SP, Cold Weather
      08-25-2005, 12:30 PM   #5
Oz
Oz's Avatar
Drives: 2006 330i, 2004 X5
2006 330i  [0.00]
I didn't play with the EQ yet but I will definitely try this. I was wondering why the system didn't have presets for it..Thanks for the idea
Would you be able to take a picture of the EQ on your car?
2006 330i Steptronic/Alpine White/Black Leather/Burl Walnut Trim/Premium Package/iDrive/Heated Seats/Winter: STYLE 159 Blizzak LM-22 RFT/Summer: TBD
2004 X5 Steptronic/Alpine White/Grey Leather/Poplar Trim/Premium Package/Heated Seats/iPod Adapter
      08-25-2005, 01:36 PM   #6
jlr
Drives: 2006 33i
EQ settings should not be flat and I will post pix
MonacoBlueNJ,
The EQ is not to be flat. If it is flat it means you might as well not have it. I can tell you if you change it from a flat to a V your sound
quality will go up 1000000000000 percent. If you set you EQ and base. By changing the settingns my car stereo I went from a AM radio
to a rock concert on wheels.
      08-25-2005, 01:40 PM   #7
RichReg
RichReg's Avatar
Not to mention the wonders that it does for CD & Mp3 playback!
      08-25-2005, 02:33 PM   #8
Squawks
One of my two dachshunds:
Squawks's Avatar
Drives: B6 A4 3.0 Quattro
It depends on preferences.
If you have really good speakers, which I do at home for my home theater system and my music/entertainment/DJ system, then a flat EQ is all you need. Anything else is just defiling the music.
If you have crappy speakers, then an EQ will help but obviously, that depends on every single listener's preferences. Some people like bright speakers, some like it more flat and natural.
Personally, I don't like setting the EQ to the cliche style mentioned by the OP.
I personally know how my music should sound like, and I definitely don't like to adulterate it with an EQ that makes it sound more unnatural. Of course, some people don't care if it's natural or unnatural as long as it suits them. Some people are a little deaf when it comes to low/high notes, and thus, they like to put it on the cliche'd V EQ.
The V EQ is so common and cliche'd, in fact, that most stereo head units already have a setting preset for that - it's called the 'loud' setting. While not related to amplification of the signal, all it really does is utilized the V EQ.
      08-26-2005, 05:37 PM   #9
MonacoBlueNJ
I drove with a $3000 sound quality system in my previous car...my head unit(Clarion HX-D10) had no amplification, only preouts. It also had EQ bypass, which was a pure unfiltered signal to the amps. If properly set up(signal paths and crossovers, wattage, placement, etc.) you should need no EQ. In fact, an EQ, even if left flat, would just further complicate and "muddy" the sound. Your "V" may sound good to you, and if it does, enjoy it and be thankful you aren't ijnto the expensive audio hobby.
      08-27-2005, 01:27 AM   #10
Squawks
Squawks's Avatar
Well said, Monaco.
Most folks only deal with stock/crappy amplifiers and thus rely heavily on EQs.
      08-28-2005, 04:36 PM   #11
MonacoBlueNJ
Yeah, it got too expensive for me though. Audio, especially car audio, is like an addiction-always uprading and its never quite "enough." The worst part is, $10K in stereo equipment in a car will never sound as good as a crappy $500 home setup. I've learned to live with my home setup and stock speakers in my car and spend money in other places.
