BMW 3-Series (E90 E92) Forum
Hardwired radar detector/concealed display.. post if you have one!
01-12-2010, 10:36 PM | #1 |
Bavarian Wolverine
97
Rep 525
I've read all the previous threads/posts on concealed displays but was hoping to start a new thread where anyone who has a V1 or Passport hardwired could post their setup for their E90/E92. Unfortunately there is no good spot for a concealed display (it fits nicely in the ashtray area, however I don't want to be looking down when I hear it beeping).
So post your hardwired and/or concealed display up! |
01-12-2010, 11:59 PM | #3 |
Rep 7,433
LOL is your car in limp mode in that pic??
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-13-2010, 12:10 AM | #4 |
Mmmmm.. torque....
45
Rep 367
How exactly is that attached?
2018 Imola Red F80 M3 ZCP
2016 Yas Marina Blue F82 M4 ZCP 2011 Le Mans Blue E92 M3 2010 Le Mans Blue E92 335i |
01-13-2010, 12:26 AM | #7 |
Bavarian Wolverine
97
Rep 525
01-13-2010, 12:29 AM | #8 |
G.O.A.T.!
1002
Rep 74,998
01-13-2010, 12:31 AM | #9 |
Bavarian Wolverine
97
Rep 525
01-13-2010, 01:23 AM | #11 |
Rep 5,046
Visor clip. I actually have the suction cup piece tucked in between the visor and the headliner so the visor sits at 90 degrees and faces straight forwards/back. Front tints = no suction cups
01-13-2010, 08:47 AM | #13 |
Rep 683
Here's mine clipped on the sun-visor, it's pointing down a bit but the V1 has a wide angle.
01-13-2010, 08:22 PM | #14 |
Justin Herass
333
Rep 1,205
yah i blew my charge pipe off and i was just about to fix it that day.
suction cup mount directly below the rear view mirror. gauges are gone, this is an old pic.
01-14-2010, 10:15 AM | #15 | |
Rep 4,554
Also, resize that pic, its HUGE. |
01-15-2010, 10:02 AM | #16 |
Rep 8
I think the location of the V1 is the key factor, if you have it in easy reach and where it is easy to see then you're all set, if you have it mounted elsewhere for convenience or stealth then the conceale display becomes more critical.
In terms of where to put it there are lots of options, it is quite easy to slim down the display so it is less than half an inch deep, this can open up more creative mounting options. In a cubby or the ashtray is also popular and pretty straightforward. Beyond that things get more sophisticate, I have seen the display embedded in the gauge cluster (literally in it, mounted fromm behind), mounted in to part of the console (although very model/spec dependent) or embedded within the rear view mirror. It all depends on your particular car, no solution suits everyone, do you have a flat trim area it could be embedded in? Would you be willing to pull the cluster out and start cutting? Would putting it in the rear view mirror suit you? The first question is always where you have yoru V1 an dwhere you plan to have it if you use the concealed display to control it. |
01-17-2010, 11:26 PM | #17 |
Does not play well with others
80
Rep 1,787
I hardwired mine and mounted just under the rearwiew. Passport has a hard wire kit with a small box about .75"x1"x1" on the wire that has the power onlight and a mute button and that can be mounted someplace convenient so you dont have to reach up to mute.
Sorry dont have any pics.
Tags |
concealed, display, hardwire, radar, valentine v1 |
