BMW 5-Series (G30) Forum Mechanical Maintenance - Break-in, Oil, Fluids, Servicing Transfer Case Fluid Change
      03-12-2024, 08:19 PM   #1
jumaiza
Drives: 2017 540iX
Hi. Has anyone changed their transfer case fluid and could provide some insight on their experience?
I used ISTA to open the oil chambers and I only managed to get 150 - 200ml even with a small hose. Maybe I need to use a hook or different tool. I am also not sure if I am supposed to reset calibration after the fluid change. I feel there is barely any information out there about this service for our cars.
Thank you
2017 540iX
      03-16-2024, 07:36 PM   #2
srybicki
Drives: 98 M3
Fcp euro sells a perfect bent metal tube for that. Works wonders on transfer cases and diffs.
      03-21-2024, 09:00 PM   #3
zvery777
zvery777's Avatar
Drives: 2021 M550
Thank you
2017 540iX
What are the commands in ISTA for this procedure?
      04-02-2024, 09:45 PM   #4
padresu
Drives: g30
drain, suck, refill - takes about 500ml.
I used soft hose, small diameter with large syringe
nothing to reset with ISTA
5post
