BMW 3-Series (E90 E92) Forum
Compression Test results
11-20-2023, 10:03 PM | #1 |
Rep 21
Drives: 2008 BMW 335i Coupe
How screwed am I? 2008 N54 335i coupe. 120k miles
Cyl 1: 154 Cyl 2: 151 Cyl 3: 158 Cyl 4: 152 Cyl 5: 155 Cyl 6: 135 |
12-01-2023, 04:36 PM | #5 |
Rep 69
By normal acceptable industry standards, there should not be more than a 10% drop from the highest (#3cyl), and your lowest (#6cyl). That means your allowable max is a 15.8 difference between #3 & #6. Your test results show a difference between those two cylinders is 23, so yes, #6 is subpar and the difference is over acceptable allowance.
That being said, I agree with all the above replies. Is there a performance or running issue? Are the results from a wet or dry test? If you have an issue, phils2 (post #2 above) recommendation to do a leakdown test on #6 cyl. would be a good place to start. You failed to mention how many miles you have on this engine. While #6 is subpar compared to the others, how is the engine performing otherwise? |
