10-20-2023, 06:29 PM | #1 |
Rep 50
CG VSC1 Valve Controller install question
In the installation instructions it notes to connect it to the exhaust hanger, but shows an exhaust hanger with two nuts whereas the M2 only has one nut. For those that have the valve controller installed, did you attach the box using the hanger nut or install it on top of the valve itself? This is for the OG M2 and I have a Remus exhaust.
10-21-2023, 03:58 AM | #2 |
Rep 211
I have the same exhaust and valve controller. I removed the nut for the exhaust hanger above the valve, installed the controller on the stud, and then ran the nut back on. Not sure if they changed the design in the past few years, though.
10-21-2023, 05:47 PM | #3 |
Rep 50
Thanks. Just installed it the same way and it fit perfect.
